Samsung LN40B530 vs LN40B550 need advice!
Old 12-08-2009, 3:44 AM   #1
1,547, Level: 8
Points: 1,547, Level: 8 Points: 1,547, Level: 8 Points: 1,547, Level: 8
I am about to purchase a new T.V. tomorrow. I am at a crossroad right now, I am stuck on trying to decide whether to buy a Samsung LN40B530, or a Samsung LN40B550. The differences between the T.V. are, 1 extra HDMI port for the 550, 70:000 to 1 Contrast Ratio (550) vs 60:000 to 1 (530).
The thing that is puzzling me the most is the Video Processor's for each T.V., there is a 18-bit DNIe in the 550, and an 8-bit DNIe in the 530. The main uses for my T.V. will be playing PS3, watching Blu-ray's, and watching standard definition cable.
Will I notice the additional processing power of the 550 in high definition? Will I notice the additional 10:000 to 1 contrast ratio? The price difference is a hundred dollars between the two sets. Am I justified in buying the 550? (There is a possible week to two week back order on this set). Or should I buy the 530 (which is in stock and available for tomorrow).
Thank you!
Old 13-08-2009, 12:16 AM   #2
duncfunk's Avatar
4,086, Level: 15
Points: 4,086, Level: 15 Points: 4,086, Level: 15 Points: 4,086, Level: 15
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 110, Got 228
Re: Samsung LN40B530 vs LN40B550 need advice!
I'd go for the 550
There are doubts over the 530's quality which would be even more noticable at that size
