Hi All,
Well at last we've joined the Planet of Plasma
, so it's now just a matter of getting it on the wall.
The wall is a plasterboard wall on a timber frame, then brick/breezeblock contruction. It's an outside wall, the one that would normally have the fireplace on it.
If I was to bolt/screw a sheet of 9mm MDF to the wood frame uprights, then mount the plasma bracket to this and thru to the otherside of the plasterboard with those bolts that open up (look like wings
http://www.tool-up.co.uk/shop/diy/RAW94371.html ) do you think that should be suitable enough?
many thanks again
Gary
