Philips 56PFL9954H bracket - looking for tilt or swing bracket
Old 26-06-2012, 6:00 PM   #1
Hi all,
I have a 56PFL9954H/12 TV and it's been sat on my Optimum TV stand since I bought it but happily moving house this week and can look to wall mount it
I'm looking for a TV bracket that will at least tilt and maybe pan slightly, or otherwise have one that you can pull out and angle but am concerned by the weight of the TV and if over time any swing arm type bracket I buy would bend over time due to the weight of the unit. But I really want to wall mount it to get the floorspace back in the lounge as well as finally use the ambilight to it's full potential (or is it considered a cheesy affect now?)
Can anyone please recommend a good bracket including all fixings I need? It's being mounted into a solid brick wall. Recommendation for good bolts to affix the bracket as sturdily as possible to the wall too would be great.
Thanks in advance, apologies I'm a bit of a newbie at all this
Simon
Old 28-06-2012, 10:23 AM   #2
Assured Advertiser
m-formonline's Avatar
Thanks: Gave 20, Got 305
This bracket would do the job;
http://www.m-formonline.co.uk/lcd-pl...-bracket-black
This is just 74mm deep whe pushed back and will give you tilt and swivel if needed. There's no sag in this bracket as is uses a cantilever system and pivots around the centre of the TV. Also rated to 75 Kgs with your TV being 31.5.
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
