Confused by wall mounts!
Old 17-11-2009, 10:09 PM   #1
2,909, Level: 12
Points: 2,909, Level: 12 Points: 2,909, Level: 12 Points: 2,909, Level: 12
Thanks: Gave 2, Got 0
Never wall mounted a TV before.
Looking at buying a 19" Samsung LE19B450 for the kitchen. Hoping to wall mount in a corner so will need to be flat on wall when not in use, but able to pull out and swivel when in use.
Do I need a specific type/size of wall mount? I am confused by all these references to VESA and don't know what I am supposing to be looking for.
Please help...
Old 18-11-2009, 9:49 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Confused by wall mounts!
Your TV has a 75x75 VESA mount which means that any small VESA bracket should fit. This one would do what you're after;
M-Form - 14" to 26" VESA Articulated LCD Bracket
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 22-11-2009, 5:44 PM   #3
2,909, Level: 12
Fixings
Thanks Graham
What fixings (both to the TV and to the wall) do I also need to order?
Old 23-11-2009, 7:38 AM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
The bracket comes with all the fixings you need for the TV. For wall fixings we have a recommended range on our site;
M-Form - Wall Mount Fixings
Or alternnatively look in your local hardware store for fixings appropriate to your wall construction. For a 19" screen you don't need anything too fancy for solid wall mounting. If you have a cavity wall then you need to try and find a wooden stud if you can.
Hope this helps.
Regards
Graham
Old 23-11-2009, 8:00 AM   #5
2,909, Level: 12
Originally Posted by m-formonline View Post
Hope this helps.
Regards
Graham
Thanks Graham - most helpful. Will be placing an order shortly.
The link you provided for the bracket automatically brings up the link for the 8x50 6 pack. Can I therefore assume that the 6 pack will suffice, and the 8 pack version wont be needed?
Old 23-11-2009, 8:14 AM   #6
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
A 6-pack will be fine, there's only 6 fixing points in the bracket anyway unless you want some spares.
Regards
Graham
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
Sanus VuePoint F11 Wall Mount 1...
1 price
 £18.95 Click to show/hide the offers
1 price
 Updated February 13th at 5:30am. Prices include delivery.
