| Re: how many bolts to hold a 37" screen?
Hi reevesy,
You must use all Six if thats what was supplied, I am that old to remember Feet and Inches I think thats 12mm ish.
I used that for hanging my plasma but I had 8!.
Get a good quality masonry bit and borrow if you havent got one a proper drill, and on hammer setting, it is not a problem.
One of my companies we or the staff use them all the time unless you are into granite or reinforced concrete which does take a bit of time and a couple of bits then its the kit you are using.
Hope its of help. Do it properly yes you are right piece of mind.
Waterhorse.
