Hi all,
I've purchased a Panasonic G10 42". Its on its way.
Now the size don't matter, as the wall mounts I am looking at are for TV's for 32" to 50".
But I wish to know if anyone has any advice in regard to the Vogel Wall Mounts and Cable Management.
VOGELS EFW 8305 -
£61.57
Its none tilt but and fixed but only 2cm from wall.
VOGELS EFW 8820 -
£23.70
by adding a tilt module for this you can get 15 degree titlt
VOGELS EFW 8325 -
£126.99
This is the Motion Arm that does 45 degree in either direction, which i think you can add the tilt module too aswell.
VOGELS EFW 8840 -
£104.70
Tthe column system to hide you wires etc, which you can add up to 3 devices (DVD/Bluray/Xbox/PS3/Wii/MediaCentre) via
VOGELS EFW 8825 -
£27.94
Additional AV supports
Its all very baffling..
Does the column system need to go to the floor?
Would it look weird simply hung on the wall?
Where would the power source for these devices come from?
Are these the best Wall Mounts?
Is there a cheaper way of doing thing?
What would you recommend going forward with, am I on the right lines?
http://www.son-video.com/images/dyna...40_L1_1200.jpg Mod Comment: images altered to a link, don't hotlink to images from sites you do have permission to do so from
Cabling and Walls are a headache- please help.
TV is coming in two weeks. Need to make a purchase very soon and also get my old sky dish box ready for FreeSat in that time also.
Please help and put me out of my misery and also give a guide to anyone else coming here for the same kind of advice.
