| Re: Fixing Bracet To Chimney Breast Issue's...
Hi paulmdenton,
If you have titanium bits they are not masonary bits they are wood / metal bits and will not go through masonry.
Get a masonry bit and it will work great, corded or cordless as long as its 18V doesn't matter. Hammer action on the drill unless you are using special masonry bits that you do not need to use hammer. SDS is usually a more powerful drill with a clutch normally, and has a different chuck for SDS bits but can be converted to normal chuck for normal bits.
Hopefully you read this before Mr sky man comes just say you haven't got a masonry bit and can he drill the holes for you dont say what you have been doing. He will laugh.
One of my companies we use this stuff everyday.
Hope this helps.
