Wall bracket for lg 42sl80000
Old 11-11-2009, 6:04 PM   #1
1,371, Level: 8
Points: 1,371, Level: 8 Points: 1,371, Level: 8 Points: 1,371, Level: 8
Thanks: Gave 2, Got 0
hi everyone,
i have a 32" LG sitting on a an OMNIMOUNT U2 FIXED bracket for 23" to 37" tv's.
i have asking both LG and Omnimount a few questions, but neither have been able to help me.
would an LG 42SL8000 lcd tv be able to fit on my existing bracket. i have emailed LG for the VESA measurement for the tv. but they did not know.
i am asking as this new tv is smaller and lighter than other 42 inch lcd's
any thoughts people
Old 12-11-2009, 7:53 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Wall bracket for lg 42sl80000
The LG42SL8000 is a 200 x 200 VESA fitting with M6 bolts so it should be ok on your current bracket.
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
garylegs (12-11-2009)
Old 02-01-2010, 2:08 AM   #3
1,371, Level: 8
i now have a lg429000. the VESA holes on the back are 200 x 200. i have a omnimount u2 fixed on the wall already. i need a bit of advice if i can explain what help i need.
The rails that bolt to the tv do not have seperate holes for the bolts to go in. they just have one long opening on the top half and one long opening on the bottom. i just cant get my head around that when i fix these to the back of the tv and put it on the wall i am worried that the weight of the tv will slide down the rails.
any advice would be appreciated.
Old 04-01-2010, 8:19 AM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
As long as the screws are tight then it won't slide down. The weight of the TV pulling outwards against the bracket will prevent it.
Regards
Graham
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
ASDA 52FM Premium Pivot Head HDM...
1 price
 £18.94 Click to show/hide the offers
1 price
 Updated February 13th at 5:30pm. Prices include delivery.
