| Samsung 40" UE40B7020 swing arm needed
can anyone recommend me a good swing arm for this screen. its very thin and I want it to sit as flat as possible, to the wall. but also have a swing that will allow it to turn 90" - ideally without the bracket being on show.
if this could be motorised even better...
I have seen premier mounts Am225 and AM3-B - but I am concerned how thin the screen is even if the screws will even fit.
thanks
also if you can advise anyone for an install that would be great
