Corner Mount Advice
Old 06-11-2009, 9:42 PM   #1
3,712, Level: 14
Points: 3,712, Level: 14 Points: 3,712, Level: 14 Points: 3,712, Level: 14
Thanks: Gave 13, Got 5
Corner Mount Advice
I would like a cantilever arm for my panasonic 42" plasma. I am looking for something sturdy so that when not in use it can be pushed flat into the wall (well flat 'ish) but when in use it needs to be pulled out out positioned for viewing in a corner. Here is a pic to give a rough idea of where the tv needs to be when being watched - ideally when not in use it needs to be flat in the recess (if possible).
Old 09-11-2009, 8:03 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Corner Mount Advice
Either of these would do the trick;
M-Form - 32" to 52" Articulated Universal LCD/Plasma Bracke
or
M-Form - 37" to 52" Free Motion Cantilever Bracket (Black)
The first one gives you a little more lateral movement but the second one is only 75mm thick compared to 130mm.
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 16-11-2009, 2:02 PM   #3
3,712, Level: 14
Thaks for the reply - have another thought though. I have a centre speaker to place and this is a little awkward if the plasma is on a wall bracket - do brackets exist with a fitting for the centre speaker as well?
Old 16-11-2009, 9:03 PM   #4
1,680, Level: 9
Points: 1,680, Level: 9 Points: 1,680, Level: 9 Points: 1,680, Level: 9
Thanks: Gave 0, Got 23
Hi mintster,
I have a similar set up to you, I have a free motion cantilever from Graham at M-form and had same problem.
I made a shelf across the corner, but you could put it on a stand or phone Graham and ask him if he can make a bracket to hang off the bottom of your chosen bracket. He designs these brackets. The problem with hanging centres of cantilevers if it was possible is that it would not go back to the wall as far as if it was not on.
Just looked at his website, what about the 32" - 52" corner bracket with 2 shelves, does that look any good?
Few idea's.
I would give him a ring nice guy, very helpful.
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
ASDA 52FM Premium Pivot Head HDM...
1 price
 £18.94 Click to show/hide the offers
1 price
 Updated February 13th at 3:30pm. Prices include delivery.
