Bracket/Mount recommendation
Old 02-11-2009, 12:32 PM   #1
4,513, Level: 15
Points: 4,513, Level: 15 Points: 4,513, Level: 15 Points: 4,513, Level: 15
Guys,
Can you advise a good mount/bracket for a Pioneer 507XD?
Roheel
Old 02-11-2009, 2:31 PM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Bracket/Mount recommendation
What sort of mount are you after? Flat, Tilt or Pull-out/Swivel?
Do you have a budget?
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 02-11-2009, 4:16 PM   #3
4,513, Level: 15
would like a tilt one...
Dont know what to budget really. Hence after the advise.
Old 02-11-2009, 4:39 PM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
There's plenty to choose from between the cheaper end on Amazon / E-bay etc and the branded brackets from retail stores.
As a starter, here's the tilter I'd recommend for your TV;
M-Form - 32" to 52" Tilting Universal LCD/Plasma Bracket
Not the cheapest but UK manufactured, independently tested and free delivery.
Any universal type like this will do the job to a certain extent.
Hope this helps.
Regards
Graham
Old 03-11-2009, 10:18 AM   #5
4,513, Level: 15
one quesiton i have, what bracket is the best to have a plate on the tv and then one on the wall and all i need to do is hook the tv on or off?
Is a tilt function possible with this?
Old 03-11-2009, 10:25 AM   #6
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
With this bracket you attach arms to the TV and the wall plate to the wall. Then the TV just hooks on. There are security screws which secure the TV on the bracket but if you don't use these then you can simply lift the TV off as you require.
Regards
Graham
Old 03-11-2009, 12:51 PM   #7
4,513, Level: 15
nice...
Ok will look into this.
Thanks for the help
Old 03-11-2009, 9:52 PM   #8
4,310, Level: 15
Points: 4,310, Level: 15 Points: 4,310, Level: 15 Points: 4,310, Level: 15
Thanks: Gave 222, Got 62
Roheel, I have a Pioneer 507xd and I have this tilting mount;
PLB103M Universal 32-55" LCD: Amazon.co.uk: Electronics & Photo
The side pic is when it was on my previous Panasonic plasma but as its universal, it comes with interchangeable bolts to fit a 507xd.
Hope that helps.
Bracket/Mount recommendation-dscn0768.jpg   Bracket/Mount recommendation-dscn1883.jpg
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
ASDA 52FM Premium Pivot Head HDM...
1 price
 £18.94 Click to show/hide the offers
1 price
 Updated February 13th at 7:30am. Prices include delivery.
