i have a panasonic tx-p50v10b.which we have sat on top of a unit at the moment.downside being we just got sky hd and the box doesnt fit in the unit due to its size.
now i need to get a new stand but i have few problems.ideally i would like one similar to the mform cubo2 in style. ie mounted on a column raised up. will theses designs take the weight of the panny? being a glass panel job its prett heavy.
also i need one with shelf gap big enough to accomadate a yamaha dsp-ax861se amp.which needs ideally 180mm clearance.
and just to chuck more in,i need to get a panny dmp-60bd blu ray,xbox 360,and if poss a ps3 in there.
with the amp and hd box.
any suggestions?
cheers in advance
