samsung LE40B550
Old 28-10-2009, 11:20 AM   #1
1,577, Level: 9
Points: 1,577, Level: 9 Points: 1,577, Level: 9 Points: 1,577, Level: 9
samsung LE40B550
ok after some thinking about what i wont to do next is Wall Mount the t.v any info on some good Wall Mount would be great as im new to all this and dont wont to get it wrong and wake up one morring to find my nice new t.v on the floor lol
p.s half the wall for the bracket will be brick and the other half will be plaster borad
Old 29-10-2009, 8:06 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: samsung LE40B550
Your TV has a standard VESA 200 x 200 fixing on the back. However, for a TV this size you really need a wall plate large enough to spread the load so a universal type bracket would be best. Here's the sort of thing;
M-Form - 32" to 42" SUPER SLIM LCD/Plasma Bracket
M-Form - 32" to 42" SUPER SLIM Tilting LCD/Plasma Bracket
You said you are mounting half into brick and half into plasterboard, how does this work and which half is which?
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 29-10-2009, 4:41 PM   #3
1,577, Level: 9
Originally Posted by m-formonline View Post
Regards
Graham
hi thxs for the info i live in high rise flats and the wall i am mounting the t.v has a concrete pillar running down the wall so the left side of the t.v will be over it and the rite side will be plasterborad
Old 29-10-2009, 4:45 PM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
Ah, ok. You'd probably be better with something with a solid back plate then like this;
M-Form - 32" to 52" Universal LCD/Plasma Bracket
You can use solid wall fixings in all the left side fixing points and then reinforce the bracket with plasterboard toggle fixings on the right. You'd need at least 4 fixings in the concrete though.
Regards
Graham
Old 29-10-2009, 4:45 PM   #5
1,577, Level: 9
ps i was thinking that a mount where it hangs from with say 12 / 15 plastbored screws would do the job as the t.v is only around 19kg
Old 29-10-2009, 4:49 PM   #6
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
It could be ok with that, it depends on the quality of the wall really. If you can get ANY fixings into the concrete then it would obviously help.
Regards
Graham
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
Sanus VuePoint F11 Wall Mount 1...
1 price
 £18.95 Click to show/hide the offers
1 price
 Updated February 13th at 2:30am. Prices include delivery.
