Best mount for a panasonic 50"V10
Old 25-10-2009, 4:04 PM   #1
3,801, Level: 14
Points: 3,801, Level: 14 Points: 3,801, Level: 14 Points: 3,801, Level: 14
Thanks: Gave 20, Got 24
Hi all, just purchased a new v10 panny and was lookin for information on the best wall mount to use. Im after the slimmest one I can get with no tilting or anything fancy.
Wall it is going on is plasterboard spot dabbed onto brick wall (fairly new build house) so batons to mount onto but was hoping I could just drill through the plasterboard and mount onto the brick?
all advice appreciated
Old 26-10-2009, 7:41 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Best mount for a panasonic 50"V10
We manufacture both the genuine Panasonic bracket and also universal brackets which will fit this TV.
The Panny bracket probably wouldn't suit you as it is fairly deep and also has tilt. The universal bracket I'd recommend is this one;
M-Form - 32" to 52" Universal LCD/Plasma Bracket
This has a depth of 32mm which is fairly slim but also gives you the room you need to get the cables out of this TV.
With Dot and Dab you can drill straight through and into the brick. Because of the nature of Dot and Dab it is advisable to fill in the gap between the board and brick at the fixing hole points with something like a filler or no-more-nais to make sure the board doesn't pull in when you tighten the screws.
Hope this helps
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 26-10-2009, 10:39 AM   #3
3,801, Level: 14
Graham,
Thanks for the info, hadnt really considered about the plasterboard needing something behind it to stop it bowing.
I assume that would be a case of drill the hole into the plasterboard, squirt in filler/no more nails and leave it to set, then drill through it into the brick behind?
I also then assume I can use solid wall fixings rather than plasterboard fixings? (looking at the mounting screws at the bottom of your link)
Excuse the questions, Im just trying to make sure my new (and seemingly quite heavy) tv doesnt come off the wall.
Old 26-10-2009, 10:56 AM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
Actually you can just drill the holes through into the brick all in one go, then fill the gaps if you have any. Then you can re-drill or clean out the filler once it's set. This way you know you have a constant drill hole for the plugs to go into. Then, yes, you can use solid wall fixings suitable for your brick.
Regards
Graham
moominy (27-10-2009)
Old 27-10-2009, 9:51 PM   #5
3,801, Level: 14
Graham,
Have taken your recommendation and ordered the mount and fixing bolts, thanks for the help
m-formonline (28-10-2009)
Powered by
 Latest popular product prices
Mount Massive MFS50 Wall bracket...
1 price
 £21.41 Click to show/hide the offers
1 price
Troy LCD/LED Super Flat Wall Bra...
1 price
 £17.95 Click to show/hide the offers
Troy Slim-line Single Arm TV Bra...
1 price
1 price
1 price
ASDA 52FM Premium Pivot Head HDM...
1 price
 £18.94 Click to show/hide the offers
1 price
 Updated February 13th at 3:30pm. Prices include delivery.
