| Unknown wall construction
Hi Everyone,
I've just purchased a new TV and mount for the new front room, and I thought I would investigate the wall construction for mounting the TV by cutting into it for the cables. The wall is the "exterior" wall (brick-cavity-unknown internal construction).
Unfortunately, I don't seem to be able to tell what kind of wall it is, as it doesn't seem to match with any other type of wall I've seen discussed on the forums:
The wall sounds solid everywhere I knock. Not really solid, like it was made in the 60's solid, but not obviously hollow, like an internal partition. It starts off with about 5mm of plaster, as I can cut this out fairly easily with a stanley knife, but then there is something fairly hard after this, but when drilled (no hammer action required), this gives way after another 5-10mm to something soft with dark grey dust.
I initially thought this was plaster on plasterboard dot-n-dabbed onto thermalite, but the missing plasterboard and no gap between the middle unknown material and the thermalite makes me think it is something else.
The house was built about 5 years ago by Bovis, if this helps!
