IXOS delivers fast-fit new flat screen mount range
Old 15-12-2007, 2:00 PM   #1
News Supplying Robot
206,601, Level: 100
Points: 206,601, Level: 100 Points: 206,601, Level: 100 Points: 206,601, Level: 100
Activity: 99.0%
Activity: 99.0% Activity: 99.0% Activity: 99.0%
Thanks: Gave 0, Got 273
Post IXOS delivers fast-fit new flat screen mount range
Out now is a new series of flat-screen mounts which IXOS reckons can be fitted in the space of just 15 minutes. The Overture Flat Screen Mounts come ready-assembled, hence the fast fitting time, and ship with an electronic stud finder and spirit level included in the box. They allow you...
More...
Old 15-12-2007, 4:37 PM   #2
Figment's Avatar
7,868, Level: 21
Points: 7,868, Level: 21 Points: 7,868, Level: 21 Points: 7,868, Level: 21
Thanks: Gave 27, Got 41
Re: IXOS delivers fast-fit new flat screen mount range
How can they possibly justify charging that sort of silly price for a bracket ?. They are about half the price you would pay for a reasonable screen. A complete rip off suitable only for those with more cash than sense.
Old 21-12-2007, 4:59 PM   #3
clemenzina's Avatar
5,288, Level: 17
Points: 5,288, Level: 17 Points: 5,288, Level: 17 Points: 5,288, Level: 17
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 238, Got 135
They look rather over-specified: how many new-build UK houses have walls strong enough to support 70kg or 90kg TVs?
clemenzina
Old 18-02-2008, 10:39 AM   #4
3,103, Level: 13
Points: 3,103, Level: 13 Points: 3,103, Level: 13 Points: 3,103, Level: 13
Has anyone actually bought an Ixos mount yet?
I quite liked the look of their 'Overture' XHM468 (which can be found online for a decent price). But I've heard that they are being withdrawn because they can't maintain the tilt angle?
