Scareware launched from tech blog
Old 27-10-2009, 3:35 PM   #1
News Supplying Robot
206,601, Level: 100
Points: 206,601, Level: 100 Points: 206,601, Level: 100 Points: 206,601, Level: 100
Activity: 99.0%
Activity: 99.0% Activity: 99.0% Activity: 99.0%
Thanks: Gave 0, Got 273
Post Scareware launched from tech blog
Gizmodo, one the world's biggest tech blogs, has been running adverts poisoned by malware say security experts.
More...
Old 27-10-2009, 4:16 PM   #2
1,366, Level: 8
Points: 1,366, Level: 8 Points: 1,366, Level: 8 Points: 1,366, Level: 8
Re: Scareware launched from tech blog
This has happened with a whole load of 'reputable' sources, even Google got stung by it not long ago.
Its the problem with PPC and Adverts coming from other sources, you can never tell whats in them.
Check the register.co.uk, they usually have some good information on affected sites.
Old 28-10-2009, 10:28 AM   #3
eni eni is offline
eni's Avatar
1,736, Level: 9
Points: 1,736, Level: 9 Points: 1,736, Level: 9 Points: 1,736, Level: 9
Thanks: Gave 2, Got 25
Good advice mate. Although I prefer a more esoteric, if somewhat antiquated, solution is just to learn that anyway 'software' that comes from a banner add, no matter how respectable the website is; is more likely than not either simple bloatware that does little or nothing, or is actively damaging to you and your computer!
It is one of the great things about the BBC website however - no adds, no mess, no malware. Our TV-Licenses at work chaps
