Oldest UK television discovered
Old 21-07-2009, 7:45 AM   #1
News Supplying Robot
206,601, Level: 100
Points: 206,601, Level: 100 Points: 206,601, Level: 100 Points: 206,601, Level: 100
Activity: 99.0%
Activity: 99.0% Activity: 99.0% Activity: 99.0%
Thanks: Gave 0, Got 273
Post Oldest UK television discovered
A 1936 television set is thought to be the UK's oldest working television, after a nationwide search is held.
More...
Old 21-07-2009, 8:15 AM   #2
11,437, Level: 25
Points: 11,437, Level: 25 Points: 11,437, Level: 25 Points: 11,437, Level: 25
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 257, Got 219
Re: Oldest UK television discovered
As a child I had an early interest in all things electronic. Somebody gave me an old TV set to 'play with'. It had a 9" round tube. The television signals were tuned into on the radio dial; it received radio as well. It did not work, and obviously generated potenially dangerous voltages which my parents, and I, were unaware of. In the end I broke it up mainly to get at the 12" diameter loudspeaker which worked by passing mains through the outer coil. Ouch !. My first encounter with hi-fi ! Alas the rest of the kit was dumped. I'm guessing that the set was pre-war. I still beat myself up about what I did today. Still at 12 I didn't know any better.
A local dealer has numbers of old working sets, but nothing as old as 1936. He is able to incorporate the line conversion and fit freeview to enable them to work with present day signals. I guess a lot of people would no longer tolerate the 'warming up' times before these sets spring into life.
http://www.vintagetvandwireless.com
Old 21-07-2009, 12:24 PM   #3
ukbootlegs's Avatar
13,521, Level: 27
Points: 13,521, Level: 27 Points: 13,521, Level: 27 Points: 13,521, Level: 27
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
Thanks: Gave 96, Got 206
does it support my xbox 360? :P
Old 21-07-2009, 2:42 PM   #4
mattclarkie's Avatar
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
If you got an RF modulator for your 360 (does the 360 even have one as an accessory?) then it does.
