Originally Posted by nlanks
My question is: is it worth it for a) preserving longevity and/or b) sonic improvements?
Couple of the phono socket inputs ( cd and tuner) feel like they are on the edge of breaking  |
Short answer, yes if the caps are gone or there is an issue with amp. Otherwise, No- there is nothing wrong with amp. Its not like a car it needs a oil change every few years!
8000P
If there is no buzzing like noise coming from the tweeters when the power amp is connected then there is nothing wrong with the power amp. No point wasting your money, give your cash to charity! You can pop the hood of the power amp and take a jet of compressed air to it, outside. As dust is no good for components- same as a pc. Make sure you don't touch any of the large caps and the unit is unplugged before hand. If there is then the electrolytic caps might need replacing.
8000A
Do the same with this- ear to tweeter (When no music is playing). pop hood air duster outside. If your a dab with a soldering iron you can possibly repair the phono connectors yourself. Get them on Ebay, Maplin, RS Electronics, Farnell to name a few places. Caps are easy to replace too, need to make sure they are discharged before replacing. Like replacing a light bulb! If you are uncomfortable with any of this then either Kevin or IAG (Audiolab) will sort you out.
