| 60i - 'gritty' volume control
I've just bought a TAG Mclaren 60i in the classifieds. It hadn't been used by its previous owner for a few years, and he had no facility to demo at this house. So I paid a deposit and took it for home trial (to check it works properly, not to check I was happy with the decision of a 60i).
Something has come up, please could somebody tell me if it's normal, purely a superficial problem, or something that's likely to develop into an actual problem?
The issue that I'm seeing is that the bottom 10% or so of the volume control feels rough and gritty.
I know that the volume control 'going' is fairly common on older amps, and can lead to crackles. There's a definite jump between rough and smooth - it doesn't just lessen as you turn it up.
Does it sound like I'm going to get a crackly amp in a year or two? Or is it likely to stay exactly as it is? Or, in fact, do TAG amps feel different in the bottom section of the volume control?
Currently it sounds fine so not a problem if it isn't the start of a bigger fault.
If somebody can post some thoughts ASAP that'd be great, as it's holding up the resolution of the trade.
Thanks in advance.
