How much THD (Total Harmonic Distortion) % is acceptable?
Old 23-02-2009, 2:08 AM   #1
The-One's Avatar
Thanks: Gave 24, Got 23
<10% THD <50hz is considered good usually I think? But what is acceptable? What is bad etc etc? And is 1% THD a lot better than 9% THD?
Old 23-02-2009, 8:51 AM   #2
paulst10's Avatar
Thanks: Gave 534, Got 1,160
Re: How much THD (Total Harmonic Distortion) % is acceptable?
Basically the lower THD across the entire frequency range the better
I would consider 10%THD @ 50hz quite poor (depending on how many DB's it was producing).
A reasonable THD figure (depending on subwoofer) would be something like 100db @ 30hz with 10%THD
An exceptional THD figure would be something like 100db @ 20hz with 8%THD
Old 23-02-2009, 9:19 AM   #3
cribeiro's Avatar
Thanks: Gave 187, Got 317
You mean something like this?:
http://personal.inet.fi/private/zipm...15hz%20thd.png
http://personal.inet.fi/private/zipm...thd%20comp.png
It's my setup at home (PB13-ultra in 15Hz tune ).
Old 23-02-2009, 10:44 AM   #4
paulst10's Avatar
Well yes I was going to mention the Ultra with those figures, but I didn't want to seem like I was blowing a trumpet or I may find myself moderating the new musical instruments forum
Old 23-02-2009, 6:51 PM   #5
The-One's Avatar
So would say a 5% reduction in THD at 30hz from 9% to 4% say at 100db make a lot of improvement?
Or because the THD is <10% this reduction does not matter
Old 23-02-2009, 7:11 PM   #6
paulst10's Avatar
IIRC, the audible threshold is around 10% so anything less than probably wouldn't be audible ?
