I was thinking about the plug in type rcd i don't know if it will work but I found this ,
Sound Equipment
Earth connections
Lack of maintenance of earth connections causes the commonest electrical safety problem with sound equipment. Any item of equipment which is mains powered should either be double insulated or correctly fitted with a protective earth.
If you are in any doubt about the connections of equipment, consult a competent electrician. Remember that an audio expert might not be an expert in electrical safety.
Single items of equipment, if poorly maintained, usually present very little problem. If a number of items are connected together, however, it is possible that cables screens, together with protective earths, form loops resulting in mains hum on the system.
Do NOT remove protective earth connections. This has been one of the common causes of entertainers receiving electric shocks, some of which have been fatal.
Good quality sound equipment should not cause hum although in some cases you may need to disconnect the screen at one end (only) of interconnecting audio cables. In other cases rearranging the equipment so that the wires do not crisscross the stage can solve the problem. When obtaining new equipment, discuss your needs with the supplier. Some equipment has a facility for disconnecting the 'signal' earth from the safety earth without affecting safety.
