Ok!, now I have the RS SPL meter...my new REW graph...
Old 19-11-2009, 4:00 PM   #1
2,971, Level: 12
Points: 2,971, Level: 12 Points: 2,971, Level: 12 Points: 2,971, Level: 12
Thanks: Gave 2, Got 2
I all mates!!, I'm here again since my last attempt to get my freq response with REW...well, now I finally have the RS SPL meter (analog model 33-4050), and I want to tell you how I did the measurement before nothing...
I set my meter in the listening position (with a tripod)...with an RCA-to-RCA cable, I connected the RS out to the right RCA-in of the jack-to-double RCA conversor like this one:
Then, the conversor to the mic-in (in the LINE-IN mode of course) of the laptop. Finally, the headphones-out of the laptop to the V-AUX-in of my Denon with a jack-to-double RCA cable (both RCA connectors fitted to the AVR but im not sure if I should connect just oneż?). Ok these are the connections, now the calibration...
With the calibration tone for subwoofers (and the speakers off in my amp) I set the volume in my Denon until the SPL meter measured 75db, in the 80db range(wich was very hard to do, because the needle of the meter was moving continously almost 3db up and down, due to fluctuations in the tone volume wich I could confirm just by ear and I think its a room problem). The meter was set in C and Slow. Once I had the sub at 75db I raised the meter range to 90db because I got some clip when calibrating, so I set the 90db range, then press calibrate again and finally I tell REW that the level was 75db for the new range.(I supose all that is correct)...then I had not any clipping. The crossover is at 80Hz from the receiver and REW...the sound card and the meter compensation files are loaded. Well this is the result:
and with 1/3 smoothing:
......looks really BAD!!!!! seems like I have a cancellation at 20Hz...ˇˇˇ20Hz!!!!...and nothing below that...what do you think guys???...do you recomend me to buy a FBQ-2496??? can it make any improvement in the response?? (specially in the lower zone??)
Many thanks!!!...and sorry for my bad english...
Old 20-11-2009, 1:08 PM   #2
Iron Man 2's Avatar
4,407, Level: 15
Points: 4,407, Level: 15 Points: 4,407, Level: 15 Points: 4,407, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 109, Got 62
You might want to try moving it around the room. I had a very boomy sound with music and ran REW which showed a number of peaks and dips. Moving the sub around the room 1ft at a time improved the graphs and sound considerable.
Still not perfect but a work in progress.
Old 20-11-2009, 2:02 PM   #3
cribeiro's Avatar
12,608, Level: 26
Points: 12,608, Level: 26 Points: 12,608, Level: 26 Points: 12,608, Level: 26
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 183, Got 302
Originally Posted by Iron Man 2 View Post
You might want to try moving it around the room. I had a very boomy sound with music and ran REW which showed a number of peaks and dips. [...]
Wait... you have a B&W PV1 and measure a in-room response extending down to 10Hz?
Old 20-11-2009, 2:11 PM   #4
2,971, Level: 12
many thanks for your reply!!!...the problem is that I have a very, very limited space for moving the sub, almost nothing...maybe I can move it just a few inches, but nothing more...I cant believe it...I would never think that I could have a cancellation at such a low frequency, as every body seems to have a nice "flat" and "soft" response below that frequency...you for example dont have any problem in the low bass, indeed below 40Hz you dot have any problem, so in the worst case you only must to lower the crossover(or buying a bfd or fbq and you will have a brutal response), but I dont know what to do......I supose there is not any problem with my Monolith right???...it sounds well, but this brutal roll-off in 20Hz looks weird...
Many thanks and bye!!
Old 20-11-2009, 11:13 PM   #5
Iron Man 2's Avatar
4,407, Level: 15
Activity: 0.8%
As you can see it was rolling off at just 30hz before I started moving and then applying EQ. Most acoustic problems are the room not the speaker. The same REW sweeps were applied to all positions and the setup was reviewed by the guys on the REW forum.
Old 20-11-2009, 11:15 PM   #6
Iron Man 2's Avatar
4,407, Level: 15
Activity: 0.8%
to achieve that graph I simply twisted the sub approx 30 degrees. Before that there were some serious peaks. Even slight movements can make a big difference.
Old 20-11-2009, 11:52 PM   #7
Tyler Durden's Avatar
6,311, Level: 18
Points: 6,311, Level: 18 Points: 6,311, Level: 18 Points: 6,311, Level: 18
Thanks: Gave 134, Got 66
It's all fun and games. Moving the sub inches will make big differences, as will moving the SPL!
Enjoy!
Old 21-11-2009, 10:59 AM   #8
2,971, Level: 12
Ok!, I will try moving it around a few inches...the SPL meter seems very sensible too...I set it in a tripod and in a horizontal plane, is that correct??.
Anyway, would you recomend me buying an eq?? the FBQ 2496 in this case, as I cant find the BFD now.
Bye
Old 22-11-2009, 11:04 AM   #9
cribeiro's Avatar
12,608, Level: 26
Activity: 2.1%
It's not recommendable to apply EQ beyond the roll-off point of the subwoofer. It will simply struggle to produce some output that it can't. Of course, it won't be serious unless you want to go loud, but your headroom (how loud you can go) is strongly limited when you do that. I am surprised that the guys at the REW forum did not say anything about it , and I feel confident that I am not missing anything here
It would be interesting to see the response curves at 70, 80, 90 and 100dB. I guess you know this
B&W Pv1 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Which shows strong compression when reaching 100dB, and that's without lifting up the low-end. I understand you lifted it by 10dB, which leaves you with compression at 90dB
Old 22-11-2009, 3:14 PM   #10
Iron Man 2's Avatar
4,407, Level: 15
Activity: 0.8%
I didnt apply any eq beyond the roll off point. I only applied it in the range 65-85Hz. The amp only allows you to eq at 3 points. any other changes in the curve were due to moving it arround the room.
Old 22-11-2009, 5:12 PM   #11
cribeiro's Avatar
12,608, Level: 26
Activity: 2.1%
Ok, then I misunderstood what you wrote previously That's quite an impressive response for a PV1, actually
Old 22-11-2009, 5:57 PM   #12
Iron Man 2's Avatar
4,407, Level: 15
Activity: 0.8%
Cheers, I probably will still get a BFD to flatten it out further
Powered by
 Latest popular product prices
Yamaha YST-FSW050 Subwoofer Black
1 price
 £112.00 Click to show/hide the offers
Behringer Eurolive VP1800S Subwo...
1 price
 £150.00 Click to show/hide the offers
Onkyo SKW-208 Subwoofer Silver
1 price
 £175.02 Click to show/hide the offers
Yamaha YST-FSW100PF Subwoofer Black
1 price
 £175.00 Click to show/hide the offers
Jamo SUB 210 Subwoofer High Glos...
1 price
 £188.68 Click to show/hide the offers
Tangent Evo Subwoofer Black
1 price
 £279.99 Click to show/hide the offers
Pioneer TS-WX20LPA
1 price
 £280.46 Click to show/hide the offers
JBL Northridge E 150 P
1 price
 £292.76 Click to show/hide the offers
 Updated February 13th at 9:30pm. Prices include delivery.
