High Level and Monobloc Power Amps - shared common\negative.
Old 14-11-2009, 5:44 PM   #1
drummerjohn's Avatar
8,478, Level: 22
Points: 8,478, Level: 22 Points: 8,478, Level: 22 Points: 8,478, Level: 22
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 58, Got 131
Trying to use high level input on BK Monolith. I have two monobloc amps. The Monolith uses a shared common. Is this going to work as I have seperate amps. I don't want things to go bang as it were.
Old 14-11-2009, 9:54 PM   #2
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Points: 24,796, Level: 38 Points: 24,796, Level: 38 Points: 24,796, Level: 38
Activity: 22.8%
Activity: 22.8% Activity: 22.8% Activity: 22.8%
Thanks: Gave 355, Got 1,104
Re: High Level and Monobloc Power Amps - shared common\negative.
I cant see any reason as to why it wouldnt work. The high level connections only read whats happening with the signal the power amps send out, the amps dont actually power the sub in an way. The signal levels are incredibly low so you wont have any problems
Old 15-11-2009, 1:42 AM   #3
AVF Hardware Reviewer
Russell.Williams's Avatar
34,278, Level: 45
Points: 34,278, Level: 45 Points: 34,278, Level: 45 Points: 34,278, Level: 45
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 745, Got 1,451
Unless those monoblocks are an internally bridged configuration, in which case a bit of care may be advised. What monoblocks are you using?
Also, given your current kit list, I can see no reason why you should actually want to use the high level connections. Unless you have a separate stereo setup, I'd run the speakers as small and do everything you possibly can to avoid the 820 getting involved in power sapping bass.
Russell
Old 15-11-2009, 10:28 AM   #4
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
Thats not a bad point Russell, how do the mono blocs figure into the equation with your AV amp etc.
Old 15-11-2009, 10:39 AM   #5
8,478, Level: 22
Activity: 5.7%
Sorry, this is a seperate setup to my sig.
On the Monolith I use the low level for my AV.
My stereo setup is a PC feeding a Beresford DAC that then feeds two mono amps... they're not bridged. They are on the same chassis just not joined electronically at all. See below.
My DIY Power Amp
Old 15-11-2009, 10:56 AM   #6
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
High level will be fine then , and nice build
Powered by
 Latest popular product prices
Yamaha YST-FSW050 Subwoofer Black
1 price
 £112.00 Click to show/hide the offers
Behringer Eurolive VP1800S Subwo...
1 price
 £130.80 Click to show/hide the offers
Onkyo SKW-208 Subwoofer Silver
1 price
 £175.02 Click to show/hide the offers
Yamaha YST-FSW100PF Subwoofer Black
1 price
 £175.00 Click to show/hide the offers
Jamo SUB 210 Subwoofer High Glos...
1 price
 £188.68 Click to show/hide the offers
Tangent Evo Subwoofer Black
1 price
 £279.99 Click to show/hide the offers
JBL Northridge E 150 P
1 price
 £292.76 Click to show/hide the offers
Polk PSW110 Black
1 price
 £299.00 Click to show/hide the offers
 Updated February 11th at 9:30pm. Prices include delivery.
