| Re: Crossover question
I'm no expert but if your speakers are 80-240khz and you set the sub to 60hz crossover then you have a hole of a 20hz band being dropped.
here on AV type amps the recommended setting is for the amp to control the crossover with the subs crossover turned round to max.
example
speakers 60-24khz set the crossover in the amp on the sub setting to 60hz, if you dont have a av amp with a sub out and using highlevel outputs into the sub, then use the crossover setting on the rear of the sub and set at 60hz.
so range of music will be 60-24khz your speakers will play and what your speakers cant handle 60hz and below will be done by the sub.
hope that makes sense ?
cant find the spec for yours but the newer MS05i come down to 65hz so after 65hz your subs needs to do its bit but experiment 70-80hz on the sub, if you start going higher your asking the sub to play higher ranges which some subs dont do well but experiment and see how it sounds.
