Upgrade From BK Gemini - Dimensions Critical - Advice Please
Old 13-11-2009, 10:52 AM   #1
Eltee's Avatar
3,659, Level: 14
Points: 3,659, Level: 14 Points: 3,659, Level: 14 Points: 3,659, Level: 14
Thanks: Gave 147, Got 71
Question Upgrade From BK Gemini - Dimensions Critical - Advice Please
Denon AVR-1909
B&W M1's
BK Gemini (Mk1)
I am looking to upgrade my sub.
Size is critical as it has to be placed behind the plasma in the same area currently occupued by my faithful BK Gemini (which I will advertise on here in due course).
The room is fairly large, roughly 7m x 7m with a 2.5m ceiling.
Main use is Blu-Ray/Sky HD related.
Originally, I was considering a PV-1 to match in with my lovely M1's but my BK brand loyalty has pointed me in the direction of the much more sensibly-priced XLS-200 or the XLS-300. Anything else out there worth considering, new or used?
They both represent the maximum dimensions. I can't really fit anything else in so don't dangle a Monolith under my nose
Any advice appreciated.
Old 13-11-2009, 11:32 AM   #2
2,124, Level: 10
Points: 2,124, Level: 10 Points: 2,124, Level: 10 Points: 2,124, Level: 10
Thanks: Gave 0, Got 3
Re: Upgrade From BK Gemini - Dimensions Critical - Advice Please
what about the BK xxls 400, its only slightly bigger...
Old 13-11-2009, 11:37 AM   #3
acid007's Avatar
3,529, Level: 13
Points: 3,529, Level: 13 Points: 3,529, Level: 13 Points: 3,529, Level: 13
Thanks: Gave 80, Got 215
The BK-XXLS400 would be my suggestion, i am in a similar postion to you and have ordered it.
Looking forward for it to arrive.
Old 13-11-2009, 11:43 AM   #4
Eltee's Avatar
3,659, Level: 14
Interesting...
What are the dimensions of a '400 then?
Old 13-11-2009, 12:56 PM   #5
3,200, Level: 13
Points: 3,200, Level: 13 Points: 3,200, Level: 13 Points: 3,200, Level: 13
Thanks: Gave 21, Got 25
BK 400 = Dimensions:400D x 460H x 400W
BK 300 = Dimensions:380D X 350H x 400W
Bk 200 = Dimensions:390D x 295H x 295W Forward Firing
BK 200 = Dimensions:340D x 355H x 290W Downward Firing
Gemini = Dimensions:315D x 355H x 290W Mk2 Version
You can see from the above the Mk2 Gemini is nearest in size to a BK200 DF where the 400 is 60mm deeper 105mm higher and 110mm wider, depends what space you have.
maybe the BK 200 would have in what your lacking in the Gemini ? if size is the restraint ?
Old 13-11-2009, 1:11 PM   #6
Eltee's Avatar
3,659, Level: 14
Thanks for that, I think I'll do a quick re-measure and see if I can squeeze in a 400. I wonder if BK are back-ordered until this side of Christmas.
Old 13-11-2009, 2:07 PM   #7
2,124, Level: 10
i've 4 weeks to go till i get mine....
Old 13-11-2009, 2:58 PM   #8
Eltee's Avatar
3,659, Level: 14
I have just cut out the various sizes on paper and the 400 is considerably larger than the Gemini whilst the 200 is more or less the same.
Does anyone know if there a massive difference between the 400 and 300 in terms of performance?
Old 13-11-2009, 3:12 PM   #9
3,200, Level: 13
Difference between the 300 and the 400 i would say yes, but i think the difference between the Gemini you have now and the BK 200 would be a bigger jump in performance.
i have a BK 200 on order and they said 2 weeks from last mondays order
Old 13-11-2009, 5:20 PM   #10
Eltee's Avatar
3,659, Level: 14
....must....try....to...shoe-horn....in....XXLS 400
Old 15-11-2009, 2:20 PM   #11
Eltee's Avatar
3,659, Level: 14
Short of taking a jig saw to my kit I'm going to have a real struggle getting a 400 to fit. I hate slescting equipment based on size but should I go for the 200 or 300 now? I'm still confused
Old 17-11-2009, 3:54 PM   #12
Eltee's Avatar
3,659, Level: 14
Hmm. I've been looking at a SVS PC12-NSD as I reckon that the circular shape will fit snugly behind my plasma and give me the all-important volume (and volume) I am lacking
Anyone recently got one of these and would this integrate with my B&W M1's okay?
Old 17-11-2009, 11:29 PM   #13
1,630, Level: 9
Points: 1,630, Level: 9 Points: 1,630, Level: 9 Points: 1,630, Level: 9
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 26, Got 215
Its a sub surely any half decent sub will do the job of integrating with anything. I would'nt worry about that. Setting it up might be a different issue. I also essentially have one place that my sub can go and I had a bit of a job getting the thing matched with my other 5 speakers in terms of my seating position. I ended up with the gain at 2/3 to get my SPL meter readings right, even then at low volumes I think the sub is over powering the other channels. I guess the thing to do is buy it and see how you go! If you're happy thats all that matters.
Eltee (18-11-2009)
Old 18-11-2009, 9:21 AM   #14
Eltee's Avatar
3,659, Level: 14
Thanks eaglemoomin. I'll run Audyssey and see what it throws up first but by the sounds of it I'll be breaking out the SPL meter. double checked for size (with a cut-out template) last night and it looks like the SVS is a go
Powered by
 Latest popular product prices
Yamaha YST-FSW050 Subwoofer Black
1 price
 £112.00 Click to show/hide the offers
Behringer Eurolive VP1800S Subwo...
1 price
 £150.00 Click to show/hide the offers
Onkyo SKW-208 Subwoofer Silver
1 price
 £175.02 Click to show/hide the offers
Yamaha YST-FSW100PF Subwoofer Black
1 price
 £175.00 Click to show/hide the offers
Jamo SUB 210 Subwoofer High Glos...
1 price
 £188.68 Click to show/hide the offers
Tangent Evo Subwoofer Black
1 price
 £279.99 Click to show/hide the offers
Pioneer TS-WX20LPA
1 price
 £280.46 Click to show/hide the offers
JBL Northridge E 150 P
1 price
 £292.76 Click to show/hide the offers
 Updated February 14th at 2:30am. Prices include delivery.
