| Re: Help! REL Stampede suddenly stopped working - looking for ideas
other than if you see a inline fuse built in the back of the amp body then check that, and your confident its getting power then it could well be a failure on the inbuilt Power Supply circuit?
If yes to all of the above its pointing towards internal, so by all means have a look (make sure unplugged for a while) and take the back off and see if you can see any burn marks / black resisters? If so you may be able to get it repaired locally /yourself of maybe a new amp?
