Speakercraft BassX 12 problem
Old 04-11-2009, 11:25 PM   #1
Thanks: Gave 8, Got 2
One of friend had Speakercraft BassX 12 at his home and it was working very well.
I bought the sub from him as he was relocating and when I hooked it on to my system, it did not work at all. I checked the plug and the fuse at the back of the sub. Plug was fine but the fuse was blackened. It said 250V 2AMP fuse. I replaced it and the moment I tried to power up the sub, the fuse again blew. Tried it again with a new fuse and it blew again.
Can anyone please help me in understanding what went wrong and how to get it rectified.
Old 05-11-2009, 1:05 PM   #2
Thanks: Gave 61, Got 42
Re: Speakercraft BassX 12 problem
Try this e-mail: shop.admin@onidserv.com
P/S: Remember Speakercraft don't seem to allow transfer of warranty. So you might be better of if the original purchaser makes the claim.
Old 07-11-2009, 9:48 AM   #3
Thanks: Gave 14, Got 35
I have one of these, I've just checked my plug fuse and it's a 3 amp, could it be that simple? I think it's probably worth rewiring the plug and trying the slightly larger fuse.
Good luck.
Old 07-11-2009, 11:11 AM   #4
Hi Sanejo,
Thanks for the advice. I have already changed the plug but that did not work.
There is another fuse on the sub at its back. I had a 2AMP fuse in that which I replaced and replaced again but of no use. Can you please check what kind of fuse you have at the back of the sub.
Old 08-11-2009, 8:38 AM   #5
Hmm, you're right, 250v/2amp fuse on the base plate. I'm afraid this is beyond my limited knowledge. Do you know anyone with a multimeter?
