Hey all -
This is Randy from the Guitammer Co - makers of the ButtKicker line of products.
Derek S-H, We are looking into the issue you are having with the high price of the Wireless ButtKicker Kit - I'll post back when I find out more. I'm sorry you're having problems with that.
Also, reading through this thread I saw that there seems to be a lot of misconception about "tactile transducers" and especially the ButtKicker brand units.
First of all, the ButtKicker, I-Beam and even Bass-Shakers are all "transducers" AND "shakers" by definition. I-Beam and bass-shakers use voice-coil technology while the ButtKicker uses a magnetically-suspended piston.
The Guitammer Company founder / co-inventor, Ken McCaw says,
"ButtKickers are used by many hundreds of drummers, bass players, engineers, etc. to accurately monitor low frequency. For that reason, it was designed to be extremely accurate. In order to produce accurate low frequency, we went through all the obvious methods to reproduce tactile audio, including voice coil technology. We determined that using a floating piston method gave us very little inherent resonance peaks and allowed us to reproduce very accurate low-frequency, with extended low end... down to a true 5hz."
You can even look at the white paper provided by I-Beam to see this is true. We are fairly certain that the ButtKicker LFE is what they call the "Effects Device" in the chart at the bottom of page 2.
http://ibeambass.com/links-photos/I-BEAM-WP.pdf
For those who are unfamiliar, this chart measures the force of a device in a range of frequencies. You can see that the I-Beam really has very little force in the extreme low-frequencies and has an abrupt spike in power at 32Hz, then remains relatively strong up into the higher-low frequencies (..Sounds like a weather forecast..)
The ButtKicker LFE, however, shines in the lower frequencies. This chart doesn't show it, but it is just as powerful all the way down to 5Hz. If there were such a thing as an "infra-tactile experience", this would be it. Its force gently lowers as the frequency gets higher - a really good thing for movie-watching because most effects and moments you want to feel in movies happen 80Hz and below. Above that you start to feel people talking and ambient noises that can really ruin the experience. (As a side-note, our 2 Ohm transducers for musicians are stronger in the higher frequencies where it's needed).
As to the Wireless signal - our customers would have serious medical conditions if we were broadcasting 1000 Watts of power through the air. The wireless transmitters simply send the source signal from your receiver so that you can place the amplifier out of the way, back by your couch without having to run wires. Our new Kit uses wireless Bluetooth technology just like your cell phone. There is still a wire between the amp and the ButtKicker unit that carries the amplified signal.
The new Kit should be plenty for your couch. We've encountered some situations where that was not the case, but generally it's a personal preference, or the user has their LFE output set too low in their receiver.
ButtKicker transducers are extremely high-performance, and this new wireless Kit is no exception, even with an affordable price tag (at least in the States, at this point).
As always - if you ever have any questions about our products, give us a call or email us.
Randy Mullins
randy.mullins@guitammer.com
614-898-9370
