My Monolith REW graph
Old 09-07-2009, 5:00 PM   #1
12,668, Level: 27
Points: 12,668, Level: 27 Points: 12,668, Level: 27 Points: 12,668, Level: 27
Thanks: Gave 31, Got 74
hi folks,
right i've been playing around with REW in an attempt to see what my sub is doing. with help from Moonfly i created this
i'm not quite sure if this is good bad or ugly
i guess what i'm saying is HEEEEEEEEEEEEELP
Old 09-07-2009, 5:20 PM   #2
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Points: 43,239, Level: 50 Points: 43,239, Level: 50 Points: 43,239, Level: 50
Activity: 90.9%
Activity: 90.9% Activity: 90.9% Activity: 90.9%
Thanks: Gave 466, Got 1,875
Re: My Monolith REW graph
Help with what?
Doesn't look bad at the bottom, but it drops off some above 40 doesn't it?
I'm not saying that's bad though. I'd expect it's better for action movies than general telly.
Depends how your speakers interact, but if you're running an 80hz crossover, you might want to try lowering it.
Old 09-07-2009, 5:32 PM   #3
12,668, Level: 27
help with what? good question. i have no idea
the graph i posted is the sub on it's own, i disconnected the main speakers. i have my crossovers set to 80 on the onk 875
i guess i really wanted to know if that was an acceptable response from my monolith
Old 09-07-2009, 5:51 PM   #4
Conspicuous Member
18,418, Level: 32
Points: 18,418, Level: 32 Points: 18,418, Level: 32 Points: 18,418, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 263, Got 636
Bung a BFD into the mix with quite a broad cut at 35hz and Bob's yer uncle.
If not, it would probably be great for films, as it is, with plenty of bottom end welly.
Might be a bit heavy for music.
andicapped (09-07-2009)
Old 09-07-2009, 5:59 PM   #5
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Yes, it looks fine at the bottom end
I realise that's sub only, which is why I mentioned speaker integration.
I'd run another sweep now with the speakers, to see what you get.
I'm guessing you'll see a fair dip in the 40-70 area. There's a lot of info to be had there, which is why I think letting your speakers do a bit more might be of benefit.
But as Nimby suggests, you have a good case for using a BFD, as you could cut the bottom to suit
The main point is you've got decent bottom end, so you've got options
Old 09-07-2009, 6:03 PM   #6
12,668, Level: 27
good good, i have a dedicated room thats just for films and PS3 gaming duties, so no music.
i'll have a think about a BFD, any other suggestions or should i leave it as it is.
i'd quite like to know what i'm looking at, to be honest it makes no sense to me, if someone would be good enough to break it down for me so i understand it a little it'd be much appreciated
Old 09-07-2009, 6:23 PM   #7
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Blimey, there's every chance you don't have to do anything then
How to explain it?
Hmm, well basically the blue line is the one you're aiming for, for a flat response that is.
Your response, the green line, does track it pretty well, but as you can see it rises fairly rapidly below 40hz. Whilst it's not ideal for music (because it'll sound one-noted and too deep) it's ideal for anything with a boom crash bang type soundtrack, because all the noisy effects will be enhanced
Not necessarily 100% accurate, but bloody good fun
So in your case, I don't think I'd do anything at all, which is a bonus.
I'd still like to see a curve of everything running though, just out of interest.
The point I suppose is, if you're happy with how it sounds, leave well alone
Old 09-07-2009, 6:34 PM   #8
12,668, Level: 27
i've just reconnected my front speakers and done another graph, i have NOT altered anything and here it is
Old 09-07-2009, 6:49 PM   #9
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
What did I tell you Andy
hook line and sinker
Old 09-07-2009, 6:51 PM   #10
7,387, Level: 20
Points: 7,387, Level: 20 Points: 7,387, Level: 20 Points: 7,387, Level: 20
Thanks: Gave 132, Got 211
Mine also had a massive dip after I ran mains + sub together.
I levelled it out by removing the cut filters I had on the BFD at that frequency, so they both levelled out nicely. honestly don't know if that's correct or why (constructive interference ) but the graph looked nice.
Have a read up on the american forum where there are in depth guides to house curves. I still haven't got it all or sure if I have even done it correctly, but when I posted over there the guys said an awful lot I followed from their guides was a little old and the wrong way of doing it.
Just been enjoying films since rather than tweaking
Old 09-07-2009, 6:57 PM   #11
12,668, Level: 27
you were right Al
What have i done ...................................
Old 09-07-2009, 6:59 PM   #12
IronGiant's Avatar
25,172, Level: 38
Points: 25,172, Level: 38 Points: 25,172, Level: 38 Points: 25,172, Level: 38
Activity: 33.3%
Activity: 33.3% Activity: 33.3% Activity: 33.3%
Thanks: Gave 2,333, Got 4,985
Flip the phase switch on the sub and run it again
Old 09-07-2009, 7:00 PM   #13
12,668, Level: 27
the above graph with the front speakers connected is without smoothing if that makes any difference.
Ad- i had a little read on the american site and to be quiet honest i got completely lost. think i've had too many beers to be messing around with this.
i'll have another look and see what i can come up with
Old 09-07-2009, 7:01 PM   #14
IronGiant's Avatar
25,172, Level: 38
Activity: 33.3%
Try it
Old 09-07-2009, 7:02 PM   #15
12,668, Level: 27
irongiant--- i have a phase knob not a switch. it's currently at 0 do you mean turn it all the way round? or just to the 1st mark, sub instructions say the turn to 1st mark
Old 09-07-2009, 7:03 PM   #16
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
As said, run it with the phase switched and the same limits (15-200).
And smoothed.
Old 09-07-2009, 7:07 PM   #17
12,668, Level: 27
ok phase knob turned all the way
Old 09-07-2009, 7:09 PM   #18
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
That looks better, but run it with all speakers 15-200.
Old 09-07-2009, 7:11 PM   #19
12,668, Level: 27
? what ya mean?
Old 09-07-2009, 7:15 PM   #20
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Run the speakers and sub with the freq limits set 15 to 200, so it looks similar to your first graph.
Old 09-07-2009, 7:21 PM   #21
IronGiant's Avatar
25,172, Level: 38
Activity: 33.3%
He did didn't he?
Old 09-07-2009, 7:21 PM   #22
12,668, Level: 27
thats what that graph is, i think.
all speakers connected, sub connected. do i need to hange a setting on my amp? sorry if i'm being a bit thick here. amp is currently set to stereo
Old 09-07-2009, 7:29 PM   #23
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Oh sorry, I thought that was sub only.
The previous one showed a massive dip at 70, but you've sorted it with phase.
I wouldn't be too unhappy with that.
How's it sound in comparison with just that phase adjustment?
Old 09-07-2009, 7:32 PM   #24
12,668, Level: 27
dunno too much tweaking not enough film watchin
would a BFD help me flatten this out a bit or would it not be worth it?
Old 09-07-2009, 7:35 PM   #25
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
I'd be happy with that.
It's pretty flat from 40hz up which is where most stuff is, with a nice rise in the bottom end, for effects.
I'd say job done myself.
Of course the proof is in the pudding
Old 09-07-2009, 7:54 PM   #26
12,668, Level: 27
just played the 1st 10mins of Bond Q of S and it sounds superb, maybe it's wishful thinking by my ears or it actually does sound better
thanks for the help guys, i'm sure i'll be back for some more
Old 09-07-2009, 7:57 PM   #27
2,971, Level: 12
Points: 2,971, Level: 12 Points: 2,971, Level: 12 Points: 2,971, Level: 12
Thanks: Gave 2, Got 2
hope you enjoy it, it looks great!!! at least more than Im ejoying mine ...http://www.avforums.com/forums/subwo...nolith-me.html...do you have any equalizer??
Old 09-07-2009, 8:04 PM   #28
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
If you were running it as in post #8 before, I'll bet it sounds decidedly better and it wont be imagined. You've raised the bass significantly in the area that is most important generally
Old 09-07-2009, 8:24 PM   #29
12,668, Level: 27
Watermanpc--- no no eq, just onkyo 875 and monolith
badger0-0 --- yep, one of the first graphs i made looked like that if not worse, so i guess it does sound better, certainly seems a lot more solid
Old 09-07-2009, 8:31 PM   #30
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Just goes to show how important phase can be sometimes
Powered by
 Latest popular product prices
Yamaha YST-FSW050 Subwoofer Black
1 price
 £112.00 Click to show/hide the offers
Onkyo SKW-208 Subwoofer Silver
1 price
 £175.02 Click to show/hide the offers
Behringer Eurolive VP1800S Subwo...
1 price
 £130.80 Click to show/hide the offers
Yamaha YST-FSW100PF Subwoofer Black
1 price
 £175.00 Click to show/hide the offers
Jamo SUB 210 Subwoofer High Glos...
1 price
 £188.68 Click to show/hide the offers
Tangent Evo Subwoofer Black
1 price
 £279.99 Click to show/hide the offers
Pioneer TS-WX20LPA
1 price
 £280.46 Click to show/hide the offers
JBL Northridge E 150 P
1 price
 £292.76 Click to show/hide the offers
 Updated February 11th at 7:30am. Prices include delivery.
