AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Streamers and Network Music Players
LinkBack Thread Tools Display Modes
Old 29-09-2007, 4:29 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Changing Home system from cd to mp3 - Best option?
I'm looking at ways to change my music system from cd to mp3. But I don't want to compromise on sound quality. My current cd player cost £1500 so replacing it will be difficult. In fact impossible. But what is the best option if I wanted to do it?
I know of the Slim Devices Transporter which seems like a good option. But what options do I have with mp3 players?
Are there any with digital outputs that I can connect to seperate DAC?
Are there ipod docks that are good enough to replace my £2800 cd/amp combo?
Are there any external hifi DACs that accept USB?
Answers to the above questions would be grateful
carleast is offline
Old 29-09-2007, 5:06 PM   #2 (permalink)
Thanks: Gave 19, Got 96
Re: Changing Home system from cd to mp3 - Best option?
So, you're going to have to digitise your music to a lossless format like FLAC or Apple lossless to retain any semblance of quality.
IIRC, you can now get a modified iPod and dock which provides a digital feed into a DAC of your choice. Even a 'good' Ipod analogue dock like the Arcam will be limited to the quality, decent though is, of the DAC in the Ipod.
You could go for a premium quality, PC based music player. Google for the PDF "The art of building Computer Transports" for one view on how to optimise a PC for music ripping and playback.
IMHO, as a Transporter owner, it provides excellent quality on FLAC playback and I can easily convert to MP3 V0 for my Ipod.
amcluesent is offline
Old 03-10-2007, 12:42 PM   #3 (permalink)
Thanks: Gave 7, Got 76
A suggestion:
- Use EAC (Exact Audio Copy) to cut all of your CDs to FLAC. FLAC is a non-lossy compression and with decent gear sounds better than MP3. If you chose to cut to MP3 later, you can do a mass conversion using Foobar2000. Note that both of those software packages are freeware. EAC will also Tag all of your CDs automatically.
- Get yourself a couple of hard drives for your PC. Put your FLAC on one of the drives for general use and use the second for a full copy of the first. It took me over a month to cut my 500 CDs to FLAC. A second drive will only cost a max of £100, and is well worth it for the safety of covering for WHEN your hard drive fails. Drive failure is not common, but it'll happen eventually.
- Buy a Wifi enabled router. Netgear make some decent units at sensible prices which are a doddle to setup and support 802.11B and G. Ensure you use WPA encryption to prevent your neighbours stealing bandwidth.
- The best streaming audio player I've come across it the SB+. It's a super-hot rodded Squeezebox3 with improved PSU, clocks etc. Not cheap at around £1k, but can compete with some seriously high end CDPs. By streaming from a PC, it does mean that you don't need a noisy PC anywhere near your stereo, definitely good from an aesthetics perspective.
SB+, Bel Canto Evo2i, Impulse Ta'us, Coherent system, audio technica and Zanash cables, Stillpoints. PS3 with PlayTV, Panasonic AE1000, Thule PR250B processor, Kef 3005 (rears) driven by a Kenwood 3020se.
Mr_Sukebe is offline
changing, home, mp3, option, system
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
