AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Streamers and Network Music Players
LinkBack Thread Tools Display Modes
Old 24-08-2007, 6:36 PM   #1 (permalink)
apple lossless or itunes plus? which is the better sound quality?
i know that itunes plus comes in at 256kpbs. so could someone tell me which one has better sound quality as ive ordered the new 80 gb ipod. cheers
gooner26 is offline
Old 24-08-2007, 7:06 PM   #2 (permalink)
cwick's Avatar
Thanks: Gave 29, Got 58
Re: apple lossless or itunes plus? which is the better sound quality?
apple lossless.
Recently played | Mac mini -> Off-Ramp Turbo -> DAC-1 ->Rega Mira III ->Totem Arro & Velo SPL800II
Support ORG
cwick is offline
Old 25-08-2007, 10:57 AM   #3 (permalink)
Thanks: Gave 4, Got 6
Sorry cwick but itunes plus offers higher quality music,
If you open the itunes store home and click "iTunes Plus"(right hand column of the home page)>"FAQ" then the first question explains the difference
cheers
swisspolo is offline
Old 25-08-2007, 11:59 AM   #4 (permalink)
Autopilot's Avatar
Thanks: Gave 164, Got 287
No, Sorry, but thats not true - cwick is (technically) quite right.
Originally Posted by Apple.com
California—May 30, 2007—Apple® today launched iTunes® Plus—DRM-free music tracks featuring high quality 256 kbps AAC encoding for audio quality virtually indistinguishable from the original recordings
They might sound good, but they are technically inferior in sound quality to Apple lossless. While most people wont be able to tell any difference on their iPod, played through a good HiFi you would notice a small difference as it's still compressed and lossy, no mater what the spin Apple put on it. Lossless is just that - none of the original sound information from the original CD is lost.
While it's nice that Apple are providing better quality downloads (previous bites were pathetic IMO), 256 is still pretty middle of the road. Lossless will take up more space, but if you have the room on your HDD or iPod I would recommend archiving your CD collection in lossless.
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
Autopilot is offline
swisspolo (25-08-2007)
Old 25-08-2007, 12:38 PM   #5 (permalink)
I downloaded a Kate Bush song covered by Placebo called "Running up that hill". The iTunes plus song is 256kbps at a sizable 9.2MB. The copy I just downloaded is the original 128kbps and is only 4.7MB in size.
I have a NAD C 340 connected via a good Thor interconnect to my iMac with a pair of Mordaunt-Short Avant 902i's connected with decent cables. Granted it's not a £3000 system but it's not bad at all and I have to say that I can hear sod all different between them any way.
So I can't understand why lossless would be half the size of the lossy, especially seeing as my flac collection is still even bigger than that.
Old 25-08-2007, 12:54 PM   #6 (permalink)
cwick's Avatar
I think you're getting confused fella. Sounds like you are comparing iTunes plus songs (AAC, 256kbps) with the older iTunes songs (128kpbs). Of course, giving the same encoding scheme, 256kbps is better that 128kbps.
The original poster, however, was asking about Apple Lossless (ALAC), which isn't a format sold though iTunes, but it's the lossless format used by iTunes (i.e. if you rip your CDs, you can choose ALAC, but you can't buy stuff in ALAC).
An ALAC encoded song should be, size-wise, in the same ballpark as a FLAC song. And in theory, both being lossless, they should both sound the same too .
Cheers, Carl.
Support ORG
cwick is offline
Old 25-08-2007, 1:11 PM   #7 (permalink)
Thanks: Gave 1, Got 0
That track in lossless would be about 30MB. Ripping CDs in lossless I cant tell the difference between them and the CD on a good hifi setup, listening on my ipod with nice headphones I cant tell the difference between lossless and 320kbps. I really cant listen to downloads on my home system, makes my ears feel abused! Not tried itunes plus tho, I would say if you plan on listening on a good home system either thru ipod or pc rip cds to lossless, if you mainly listen on the move higher bitrate downloads or rip at 320kbps.
unklepepper is offline
Old 25-08-2007, 1:13 PM   #8 (permalink)
ah ha, ok sorry about that, thanks for the correction. I miss understood the first post. Had my brain been in gear I would have indeed agreed cwick and never opened my mouth in the first place. Sorry about that guys, will read posts more carefully in future!
Old 25-08-2007, 1:56 PM   #9 (permalink)
Autopilot's Avatar
Ah, that explains it then, i wondered why you where saying that
Old 26-08-2007, 9:57 AM   #10 (permalink)
i'm not an expert on this but ive chosen to use apple lossless, but then when i buy songs from itunes, what quality will i be downloading them at? its set at automatic! for the record i plan to use my 80gb ipod with a denon idock , connected to my denon micro system.
gooner26 is offline
Old 26-08-2007, 10:17 AM   #11 (permalink)
jont's Avatar
Location: Now hanginaround Aylesbury instead of hanginaround Glasgow
Thanks: Gave 31, Got 204
Tracks will be 128kbps AAC unless it offers/you choose the iTunes plus tracks which will be at 256kbps AAC ... when you rip from your own cd's using Apple Lossless the rate will vary but probably be around 650-750kbps ...
HTH
Jon
my toys ... Arcam FMJ AV8, P7, DV27A+sdi | B&W 805s & HTM2 | Anthony Gallo Micros & sub | Sanyo Z4 | Samsung LE37R8 | SkyHD | Toshiba HD-E1 | Sony BDP300 | xBox360 Elite | Wii | AppleTV | iMac 3Ghz, MacBookAir (ssd) & MacMini | Nikon D300 & 17-55mm f2.8 | 3G iPhone
jont is offline
Old 26-08-2007, 12:02 PM   #12 (permalink)
thanks for the reply. i always thought you could choose which quality you wanted when purchasing from itunes ie: you could choose to buy a song in 192kbps 0r 320kbps. but it seems this applys only for burning your cd tracks am i correct? so all songs i buy from itunes will be in 128kbps format unless it states that it is available in itunes plus which will then be 256kbps?
gooner26 is offline
Old 26-08-2007, 4:46 PM   #13 (permalink)
Yep, however the other bonus to the plus songs is that they are DRM free. So you can copy them onto more than one iPod (so long as you own it of course)
But they are 99p a song rather than ...79p i think
Old 26-08-2007, 5:38 PM   #14 (permalink)
do you know how many songs i could roughly hold in an 80GB ipod in apple lossless format?
gooner26 is offline
Old 26-08-2007, 6:17 PM   #15 (permalink)
jont's Avatar
If you assume each track to be around 4.30 mins and 30mb - then you can probably fit around 3,000 songs on an 80Gb ipod ...
Jon
jont is offline
apple, itunes, lossless, quality, sound
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
