Re: Ripping clarifications?
This is what i, and quite other around here do, and recommended it;
Get EAC, don't be affriad to learn something new. It's the best ripper and it's a myth that it's really hard to set up. Sure, Dbpower AMP is probably easier, but EAC is not that hard at all. Remember, everyone is a newbie at some point until you actually use it. Have you downloaded EAC yet and given it a test run? You confidence will soon improve. Setting it up takes just minutes if you follow a guide. I dont fully understand exactly what everything does, but you only need to set it up once. Then it's a case of feeding it CD's. You will be thankful you chose EAC when you come across a scratched CD that would put iTunes on it's arse.
Use EAC to rip to FLAC. It is IMO the best lossless format to use and it does not matter if you have an iPod. Ripping all the CD's will take time, probably days (in the case of some people, weeks+). But this is your master archive. Work on that, get it set-up well and back up to. You can pack all you CD's away safely, if you should never need to rip them again.
Then you can use something like Foobar2000, Media Monkey or Dbpower AMP to batch convert to LAME MP3 for your Ipod to another location, tags and all, in a few clicks. Of course it will take quite a long time, so do it over night or while your at work.
You might find another strategy works better for you, but that what i do. I you really are struggling, then i would say go with dbpowerAMP, or maybe Media Monkey.The Only other ripper worth considering is Cdex. Media money does have a nice library organising features and you can rip with EAC then organise with MM if you wish. I have been fiddling around for years and this is where i am with it now and sticking with it. I can just delete my MP3's if i want, the important thing is my master collection. I would have my master library in FLAC regardless of what player i use, it just so happens that the Sono's and SB3 play FLAC very nicely. I have future-proofed myself, it's flexible, I'm and i'm not tied to any particular brand, and i'm certainly not spend 2 weeks of my life again ripping CD's!
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
