AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Streamers and Network Music Players
LinkBack Thread Tools Display Modes
Old 22-07-2007, 3:49 PM   #1 (permalink)
Thanks: Gave 58, Got 18
sound levels through a squeezebox
hi
ive been ripping cds in flac to my qnap 201 and playing through a squeezebox 3,sound is excellent,only problem i have is turning sound up and down as the cds have different sound levels,is there a way of bringing sound levels simlar to each other[settings in squeezebox]i really dont want to start ripping again as ive filled 500gig up of my 1500gig harddrives
cheers
mr gothic is offline
Old 22-07-2007, 4:50 PM   #2 (permalink)
Thanks: Gave 1, Got 10
Re: sound levels through a squeezebox
Do you notice the same problem with listening to the CDs?
mark88 is offline
Old 22-07-2007, 4:54 PM   #3 (permalink)
Thanks: Gave 19, Got 96
Check out the Normalisation guide at www.slimdevices.com to set ReplayGain on the tracks & enabling this on in the SB
amcluesent is offline
Old 22-07-2007, 4:57 PM   #4 (permalink)
cheers
for the link i will check it out
Old 22-07-2007, 9:42 PM   #5 (permalink)
Autopilot's Avatar
Thanks: Gave 164, Got 287
Yep, Replaygain is the answer to this problem
You should not need to re-rip
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
Autopilot is offline
Old 22-07-2007, 11:17 PM   #6 (permalink)
hi
how do i set up replygain,ive had a look at the link,not what i have to do
your help would be great
Old 25-07-2007, 4:38 PM   #7 (permalink)
Thanks: Gave 3, Got 11
Well, try this then (its a page linked from the last one) http://wiki.slimdevices.com/index.cgi?RGFoobar
Its a step by step guide to what you need to do....
5.1-ch: Panasonic TH42PX600 plasma, Denon 2805 amp, toshiba 210E DVD, Topfield 5800 PVR, B&W MT-20 spkrs
2-ch: SlimDevices Transporter, Arcam FMJ A32 amp, MA GS-20 speakers
Ceejayav is offline
Old 25-07-2007, 4:42 PM   #8 (permalink)
cheers
levels, sound, squeezebox
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
