AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Streamers and Network Music Players
LinkBack Thread Tools Display Modes
Old 04-05-2007, 4:19 PM   #1 (permalink)
dlam's Avatar
Thanks: Gave 9, Got 0
NAS For Squeezebox - a confused little guy needs help
Hi all (yeah I know there's a post about 3 topics down asking pretty much the same question for the Sonos and I did a search, but it was all getting a bit techy so I wanted to make sure that I get the answers I need )
Basically I got a Squeezebox 3 the other day and it is all working fine, but I want to be able to access my music without my PC being turned on, so I guess I need a NAS device.
From what I can see on these forums, people are recommending things like:
http://www.amazon.co.uk/Linksys-Netw.../dp/B00062KPEI
So, am I correct that I buy one of these then plug a USB hard drive into it, plug the NAS device into my router, and my Squeezebox can access the music off the drive? How do I install the Slimserver software onto the NAS box (which I guess I am still going to need)? How do I get the Slimserver browser window open to search for new music and set things up?
Is the cheapest / easiest way to do this, or is there a better way? I definitely want a remote hard drive and don't want to build a small PC as a server, because I don't want the unsightliness of it, and I am aware of the green issues of having it running constantly too.
Any help you can give me would be gratefully appreciated (the simpler the advice the better). Thanks.
dlam is offline
Old 04-05-2007, 5:34 PM   #2 (permalink)
dlam's Avatar
Re: NAS For Squeezebox - a confused little guy needs help
Hmmm, since posting it looks like the NSLU2 is no good because it won't use the AlienBBC plugin.
From what I can see, the QNap TS-101 is now looking like the best choice for me. Anyone got any experience of using this?
dlam is offline
Old 05-05-2007, 1:24 PM   #3 (permalink)
lazymatt's Avatar
Thanks: Gave 7, Got 213
The Qnap is the easiest one to go for as it can come with Slimserver pre-installed.
If you have a look over at the Slimdevices forums, there's some discussion there about NAS drives I think.
Matt
lazymatt is offline
dlam (05-05-2007)
Old 05-05-2007, 2:11 PM   #4 (permalink)
dlam's Avatar
Since posting I have had another change of plan. I realised that I hardly ever listen to the radion and so don't really require the AlienBBC plugin. Instead I have bought myself a cheap DAB seperate for the very rare occasion I feel the need to listen to the radio, and am going to get an NSLU2 and try and figure out how to get it working! How hard can it be? *shudder*
Thanks for the tip about the Slimdevices forum. I didn't even know they had one!
dlam is offline
Old 06-05-2007, 3:08 PM   #5 (permalink)
lazymatt's Avatar
Good luck
Also worth while having a look at the Slimdevices Wiki.
Matt
lazymatt is offline
confused, guy, nas, squeezebox
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
