Re: Is Anybody Using Sonos on Ethernet via Mains?
I don't use it in that format as I have a ZP100 in the computer room with my PC plugged into the line in, and also serving speakers in the bath room next door.
However, I have tried it out with the Netgear HD ones for max bandwidth, and it worked fine. Obviously it's an 'unsupported' set up, so any problems can be a bit difficult to work out, however, Sonos and their forums are still pretty good at resolving issues.
Thing with the Sonos is that it sets up it's own MESH network, so the more active ZP's the stronger the signal. How many are you planning to run?
I've never had any drop outs with mine (except when listening to internet radio, but that's the fault of the radio stream reaching their max. number of listeners, rather than the Sonos).
Matt
