As others have stated, your local LMS based system will continue to work if mysqueezebox.com disappears.
Regarding your other concern:
Originally Posted by redmarkred I'm hoping therefore my only problem would be if any of my devices broke I would not be able to buy a new one! |
In an earlier post in this thread (post #23) I stated my intention to try and build a DIY Squeezebox using a Raspberry Pi, based on Squeezeslave or Squeezeplay. In that post I said that if I didn't succeed, someone else would. Well, Triode has gone one better and developed a software player called Squeezelite. See
Announce: Squeezelite - a small headless squeezeplay emulator for linux (alsa only). It works beautifully on a Pi. The only possible issue for some is that it is headless and so you can't control it with an IR remote. You need to use the web interface, or a Controller, or one of the smartphone apps (eg. iPeng, etc).
So if your hardware players do die, you can put one together for under £50 - hook it up to a USB DAC and you'll get a high quality player. (The experience of most people playing with the Pi - myself included - is that its onboard audio output is not good enough).
