Simple Audio Roomplayer Owner's Thread
Old 30-01-2012, 1:47 PM   #1
Conspicuous Member
AngelEyes's Avatar
Thanks: Gave 386, Got 965
I should receive my Roomplayer II from Quantum Electronics this week so thought a new thread about actual user experience would be useful, as the other thread is quite long already and doesn't contain a great deal of useful information.
Simple Audio Roomplayer Discussion | AVForums.com - UK Online
Info about the Simple Audio products can be found here: Simple Audio - Multi Room Music Systems
I spoke to SA support before purchase and it seems a few of the things I was hoping for are being tested right now so I have my fingers crossed they will be added soon (I am acutely aware this is not a sensible purchasing practice but I have had it with my SB Duets!).
  • 24bit 192Khz Support
  • Twonky Support for NAS/Server
Also worth noting is that all bit and sample-rates will be handles natively, no up or down-sampling which I believe is not true of Squeezebox touch?
Once it arrives I will post the usual pictures and follow up with a review once I have lived with it for a while. I will try and answer any questions people might have, so if there is something you would like to know, just ask and I will respond when I can. I currently run 2 x SB Duets via iPeng so should be able to provide some insight on usibility/reliability etc.
Cheers,
Adam
HMHB (31-01-2012), quantumAV (30-01-2012)
Old 30-01-2012, 5:54 PM   #2
therixonator's Avatar
Thanks: Gave 13, Got 37
Hi Adam, if the SA is a success and multiroom streaming is sorted, do you plan to adopt it in other rooms, or are you just having it in your main room?
Also, will you use a separate DAC and if so, which one?
Old 30-01-2012, 6:00 PM   #3
Conspicuous Member
AngelEyes's Avatar
I am trying it out in my main room but the long term goal is to have 2 or three rooms hooked up, probably with Roomplayer I's, but for now testing will be purely 'single room'.
I won't be purchasing a separate DAC as my processor is pretty high end already.
Adam
Old 30-01-2012, 6:32 PM   #4
Adam
I see, so you're going Digital out of the RPII into the Digital In of your AVF as its a good one.
Old 30-01-2012, 6:50 PM   #5
Conspicuous Member
AngelEyes's Avatar
That is right although I will check the analogue out anyway just to see how it compares.
Adam
Old 31-01-2012, 8:34 AM   #6
Eminent Member
HMHB's Avatar
Thanks: Gave 2,923, Got 1,521
I'd be very interested to hear about the user interface as that's one of the areas where I think my Sonos system is showing its age.
One particular problem for me is that I can't sort a playlist in alphabetical or any order so that I can check if a track is already on there or not easily. Another problem is that you can only add one track at a time to a playlist.
Old 31-01-2012, 10:25 AM   #7
Conspicuous Member
AngelEyes's Avatar
I am expecting a fairly basic functionality to begin with, it needs to be very robust after all but am hoping it does enough to keep me happy. Speed and intuitive controls are the most important for me.
I have never been what might be described as a 'Power User' with Squeezebox/iPeng, despite the huge functionality available. Creating and editing playlists is about the limit of my interest really but I will do my best to find the limits of the Roomplayer UI, so any other requests are welcome.
Adam
HMHB (31-01-2012)
Old 01-02-2012, 12:38 PM   #8
Assured Advertiser
Thanks: Gave 45, Got 320
Adam
The digital output will be enabled in the next software release due in a couple of weeks time
Old 01-02-2012, 12:39 PM   #9
Assured Advertiser
Finally, dealers received stock this morning
Old 01-02-2012, 3:07 PM   #10
Are there any plans to release a controller app for Android?
shevans (10-02-2013)
Old 01-02-2012, 4:41 PM   #11
Thanks: Gave 16, Got 2
I understand that they have one in preparation.
Old 01-02-2012, 11:27 PM   #12
24/192 ?
For some reason I thought that the SA players supported 24/192 but I heard indirectly today from a dealer that this is not correct they only support 24/96.
Can anyone confirm? I looked on the SA site and I could only find a comment saying "24 bit HD"
Maybe this is another upgrade that they plan to deliver via software upgrade.
Old 02-02-2012, 9:19 AM   #13
Assured Advertiser
24/192 is coming in a software upgrade.
wytco0 (02-02-2012)
Old 02-02-2012, 9:25 AM   #14
Eminent Member
HMHB's Avatar
Is there any sign of a bespoke controller rather than having to use an ipad/iphone etc?
Old 02-02-2012, 12:22 PM   #15
Assured Advertiser
I don't have any confirmed dates but a controller is on its way soon.
Android App is in testing at the moment so shouldn't be too far away.
Old 02-02-2012, 12:40 PM   #16
Anyone got their new player yet? whats it like ?
Old 02-02-2012, 11:52 PM   #17
simple audio
...i had a chance to listen to simple audio and i think it sounds good for its price. it sounded better than sonos or squeezebox in my opinion.(analog out)
but combination of Sonos or SB + external DAC (like CA dacmagic) would significantly outperforme simple audio.
best.
Old 03-02-2012, 12:00 AM   #18
Thast good to hear.
best.
Not sure how you could know that but its not a fair comparrison is it? it would not even be cheaper.
However even if it correct Sonos can't handle 24/96 and neither SB or Sonos can handle the planned 24/192 that SA is designed for.
Old 03-02-2012, 12:28 AM   #19
i know that becouse i did comparison and that is my opinion.
squeezebox =200 +Dacmagic =250 that gives around 450, so yes its cheaper or almost the same price, but dont get me wrong, simple audio its a fine product , just arrange a demo to find it out, best.
Old 03-02-2012, 12:58 PM   #20
Assured Advertiser
Custom-Cable's Avatar
Thanks: Gave 14, Got 102
Currently running the RPII and it is definately better sounding than the Sonos. Took about 30 minutes to add 10000+ songs to its directory and now works very well and is pretty quick when loading.
Custom-Cable - London's HiFi Headphone, DAC showroom | Audiophile Headphones | DACs | Cables
Custom-Cable are proud to be a Sennheiser Spares Specialist Partner.
Old 03-02-2012, 1:32 PM   #21
Is that a digital out or analogue comparison your doing custom cable?
Old 03-02-2012, 2:01 PM   #22
Eminent Member
HMHB's Avatar
Any thoughts about the user interface yet?
Old 03-02-2012, 2:17 PM   #23
Assured Advertiser
UI is good on the PC. Functionality in regards to the iPhone/iPad app I am struggling to specify playing a certain track on an album. When selecting an album it plays from the start of the album and no way to select a track. This may be that I havn't found how to do it yet. I am using the L/R connections into MF M6 series amplification and KEF 201/2's.
Old 03-02-2012, 10:00 PM   #24
Conspicuous Member
AngelEyes's Avatar
Hmmm bit annoyed to find out after I ordered it doesn't have digital out enabled.
Should be able to take a look tomorrow, just back from EuroDisney... Knackered!
Adam
Old 03-02-2012, 10:23 PM   #25
Adam
Wow I didn't know that either and as digital output is essential for me (my Lyngdorf only has digital inputs) I am very glad I have nor ordered yet. I find it annoying when this sort of restriction is not made clear.
Its starting to look as though I will have to wait a few months before deciding on the SA players as a lot of functionality I want isn't there yet.
Old 04-02-2012, 11:35 AM   #26
Thanks: Gave 48, Got 349
Adam
That's poor as the site states it has a working digital out:
Digital outputs
Electrical and optical digital outputs feed digital signals to external digital to analog converters.
Trading Standards should give them a reminder about false advertising
Old 05-02-2012, 1:03 PM   #27
Hello......perhaps I missed it....but has anyone read this link about the Simple Audio Roomplayer?
Simple Audio rolls out Roomplayer HD audio system to UK dealers | whathifi.com
Old 05-02-2012, 2:12 PM   #28
Conspicuous Member
AngelEyes's Avatar
Well I have yet to get the darn thing to scan my music library, 396 scanned and then it hangs.
No support over the weekend means I wasted the best part of a day and a half. Not particularly impressed thus far but lets see what they say come tomorrow.
Adam
Old 06-02-2012, 11:50 AM   #29
Eminent Member
HMHB's Avatar
Adam
Any better luck today?
Old 06-02-2012, 2:18 PM   #30
Conspicuous Member
AngelEyes's Avatar
No response from Support yet.
I have posted a 'First look' review on my Blog if anyone is interested in Photos and Screenshots etc. I haven't done any real listening yet due to the issues I have been having.
Simple Audio Roomplayer II Review – First look « Live Digital – Home Cinema Blog
Adam
HMHB (06-02-2012)
