Originally Posted by larkone What server software are you running? |
I've tried it with a couple of different NAS-based DLNA servers. The results in my original post were using a Buffalo Linkstation that runs PVconnect. I have now also tried a Netgear ReadyNAS running version 7.0 of Twonky server. The results are slightly different, but still not correct:
Album--can select individual albums correctly, but then tracks do not obey the #discnumber# tag correctly and so disc 2 is interspersed with disc 1. Where I have more than one album with the same tilte (eg 'Greatest Hits), all the tracks from the different artists are listed together in alphabetical order.
Artist--shows all tracks by that artist in alphabetical order
Artist/Album--allows selection and then selection of album, but then discs are again interspersed
Folder--allows selection of artist and then album (which is the folder structure I use), but the shows tracks in alphabetical order
I have also tried resetting all the ID3 tags across my entire music collection in case there was any spurious data in there (I am only using v2.3 tags), however this has not made any difference.
Yet if I use the web interface to Twonky, the tracks are correctly ordered, so it seems that the DNP is changing the order that it is being served.
