How to connect a first SB receiver with no controller.
Old 18-11-2009, 5:47 PM   #1
15,477, Level: 30
Points: 15,477, Level: 30 Points: 15,477, Level: 30 Points: 15,477, Level: 30
Thanks: Gave 22, Got 18
Have taken ownership of my first squeezebox receiver today (ie a duet without the controller.)
Have 2 iphones in the house as well as the squeezbox software for our Pronto TSU9600 remotes, so have no need to buy the controller... or so I thought.
However the manual seems to imply I can only connect the receiver to my network via the controller, and it is just sitting there flashing red.
Please, someone tell me that I can connect it to the network and the squeezebox server (currently only running softsqueeze) without having to buy a controller I don't need!
Many thanks in advance!
Old 18-11-2009, 5:55 PM   #2
3,870, Level: 14
Points: 3,870, Level: 14 Points: 3,870, Level: 14 Points: 3,870, Level: 14
Thanks: Gave 0, Got 4
Re: How to connect a first SB receiver with no controller.
You can do it, although its nowhere near as easy as having the controller. Have a look at this thread on the slimdevices forum.
maj74 (18-11-2009)
Old 18-11-2009, 11:01 PM   #3
15,477, Level: 30
Thank you so much for the quick response and link.
I must admit that software is a godsend. It takes a little bit of decoding of the manual I must admit, but once I'd worked my way through the logic, success! Receiver connected and working.
Many thanks.
Old 20-11-2009, 8:37 PM   #4
Conspicuous Member
Crocodile's Avatar
15,125, Level: 29
Points: 15,125, Level: 29 Points: 15,125, Level: 29 Points: 15,125, Level: 29
Activity: 11.5%
Activity: 11.5% Activity: 11.5% Activity: 11.5%
Thanks: Gave 408, Got 1,147
I'm sure others would appreciate any tips you can offer from your experience.
Old 27-11-2009, 2:50 PM   #5
blisteringblue's Avatar
5,318, Level: 17
Points: 5,318, Level: 17 Points: 5,318, Level: 17 Points: 5,318, Level: 17
Thanks: Gave 35, Got 74
I've just done it and it took me about 7 mins from unboxing the Receiver
Instructions: https://projects.robinbowes.com/Net-...wiki/WikiStart
Slimforums Thread: Net::UDAP - SqueezeBox Receiver configuration tool - Squeezebox : Community : Forums
Here though is a quick 2 min guide for windows users who have DHCP and the receiver will be wired
1. download and run Windows Config Tool: http://slim2lirc.myown.mailcan.com/udap_shell_1_0_0.exe
2. Type the following at the prompts:
discover
conf 1
set interface=1 lan_ip_mode=1 squeezecenter_address=a.b.c.d
save_data
reset
(a.b.c.d is the ip address of your squeezecenter)
It really was that easy. It's a little more involved if you want wifi set-up but this links to example of other installations https://projects.robinbowes.com/Net-...ki/SampleUsage
Crocodile (27-11-2009)
