Squeezebox classic remote
Old 13-11-2009, 1:54 PM   #1
2,242, Level: 10
Points: 2,242, Level: 10 Points: 2,242, Level: 10 Points: 2,242, Level: 10
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 14, Got 5
Can someone help ..... i've broken my remote for my classic and cant get the US logitech website to ship to the UK & the UK support number told me to go to Comet or Tesco to see if they had any
any ideas were i can get a replacement?
cheers
Old 13-11-2009, 2:46 PM   #2
spinaltap's Avatar
7,562, Level: 20
Points: 7,562, Level: 20 Points: 7,562, Level: 20 Points: 7,562, Level: 20
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 0, Got 158
Re: Squeezebox classic remote
I suggest buying a Logitech Harmony 515 - which is £49.99 on the Logitech UK website (or from Argos)- Harmony Remotes
...which will also allow you to control other equipment, not just your Squeezebox.
Old 13-11-2009, 6:02 PM   #3
scrufftyguy's Avatar
9,094, Level: 22
Points: 9,094, Level: 22 Points: 9,094, Level: 22 Points: 9,094, Level: 22
Thanks: Gave 51, Got 46
I'm sure you used to be able to buy replacement remotes from logitech (UK) I wouldn't give up on their support it could still be worth a speculative email, you might get a different answer.
You could also try asking in the classifieds incase someone's upgraded theirs to a squeezebox controller, or ipod touch (which is another alternative for you, if your budget will stretch that far).
Old 18-11-2009, 4:45 AM   #4
977, Level: 7
Points: 977, Level: 7 Points: 977, Level: 7 Points: 977, Level: 7
Try Ripcaster. I think its www.ripcaster.co.uk
If you can't find anything on their website drop them an email.
Ken
