| Help - Sonos ZoneBridge is unresponsive
Have recently installed a basic 2 zone Sonos system as follows:
1 x ZoneBridge wired to Netgear router
2 x ZP120 zoneplayers (wireless)
1x CR200 controller
Music files streamed off a ReadyNAS (also wired to the Netgear router)
All was working fine with no problems. Got back from holiday to see an "Update Now" box on the controller, so I hit the button. The controller seemed to upgrade OK. It then went to the ZoneBridge to update and timed out on the upgrade. Never got to the 2 zoneplayers to update. Now the ZoneBridge seems unresponsive. Controller and Desktop Controller can't see the ZB and it has no power light. I've tried unplugging and powering back up and I get a white light briefly followed by 2 white flashes then nothing. Ethernet cable shows it is connected OK (green and amber lights visible at ZB end).
I'm pretty sure I have no router problem as it was working fine for weeks. Have tried several fixes including i) Factory reset of ZB (held connect button down while powering up); ii) powering everything down the back up in order of router/computer/ZoneBridge in case IP addresses were confused - still nothing. Get same reaction/light sequence from ZB each time I power up as mentioned above.
Will try Sonos support tomorrow but meantime does anyone have any other ideas?
