Mediamonkey and external DAC - how do I get it to work?
Old 01-11-2009, 12:29 AM   #1
OneDesi's Avatar
9,458, Level: 23
Points: 9,458, Level: 23 Points: 9,458, Level: 23 Points: 9,458, Level: 23
Thanks: Gave 146, Got 165
Sorry if this is in the wrong section but I am struggling with Mediamonkey.
I have recently got a USB DAC which is hooked up to my Compaq nx7010 laptop and was all recognised correctly. After disabling the Soundmax card in the laptop I can listen to MP3's from Windows Media Player through the USB DAC on my stereo
Trouble is I want to see how the DAC copes with FLAC files but for some reason I can't get Mediamonkey (latest non gold version) to output to the DAC - I am just greeted with a wall of silence even though the song is playing on Mediamonkey
Does anyone know what settings I have to change in Mediamonkey to get this to work
Old 01-11-2009, 5:10 PM   #2
OneDesi's Avatar
9,458, Level: 23
Re: Mediamonkey and external DAC - how do I get it to work?
Old 04-11-2009, 1:58 PM   #3
Bossk128's Avatar
7,648, Level: 20
Points: 7,648, Level: 20 Points: 7,648, Level: 20 Points: 7,648, Level: 20
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 59, Got 67
It's a while since I looked at this, but have you checked MM has an ASIO interface/plugin?
Old 04-11-2009, 2:38 PM   #4
Conspicuous Member
Crocodile's Avatar
15,125, Level: 29
Points: 15,125, Level: 29 Points: 15,125, Level: 29 Points: 15,125, Level: 29
Activity: 11.5%
Activity: 11.5% Activity: 11.5% Activity: 11.5%
Thanks: Gave 408, Got 1,147
Don't use MM but as an alternative, there's a FLAC codec for WMP here.
Old 04-11-2009, 2:41 PM   #5
Bossk128's Avatar
7,648, Level: 20
Activity: 0.7%
It's not just the codecs required, there needs to be a direct path from the FLAC file to the DAC. The Windows sound system 'does things' to the sound and an ASIO plugin bypasses that.
If MM thinks it's playing the files, then I bet it is decoding them into sound.
Old 04-11-2009, 10:20 PM   #6
OneDesi's Avatar
9,458, Level: 23
Thanks for replying folks (it was getting a bit lonely out here ).
I do have the FLAC plug-ins but where would I look for an ASIO Plug in?
Under Options - output plugins I have :
DirectSOund V2.2.7
MediamonkeyDirectSOund
Waveout Output
and I have it set to Mediamonkey DirectSound
Under DSP Plugins there is one call DeFX V0.97 but it is not selected
I'm just really confused as Winamp plays the FLAC files okay (I downloaded this the other night) but I really like Mediamonkey as it allows ripping as well from one package.
What do I do folks?
Old 04-11-2009, 10:21 PM   #7
OneDesi's Avatar
9,458, Level: 23
I know this will sound silly - but which link to I click and what do I do with it
Old 05-11-2009, 9:00 AM   #8
Bossk128's Avatar
7,648, Level: 20
Activity: 0.7%
MM wiki kind of hints that the WinAmp ASIO plugin works.
When I used ASIO it was using optical from my soundcard to my Bersford DAC. If you're using a USB connection, maybe you don't need ASIO, and just need to specify the DAC as a 'sound card'?
OneDesi (05-11-2009)
Old 05-11-2009, 1:29 PM   #9
OneDesi's Avatar
9,458, Level: 23
Hi - would you mind telling me how I plug in the plug in???
Old 05-11-2009, 2:05 PM   #10
Bossk128's Avatar
7,648, Level: 20
Activity: 0.7%
I'd have to read the instructions on the page linked above, but roughly:
Install the ASIO4All application from it's website.
Download the ASIO plugin from the Japanese site and copy to your MM plugin folder (then reboot MM).
Download WinAmp plugin and again copy to MMs plugin folder (I don't know why...)
tell MM to use the ASIO plugin, which can be configured in the plug in pages.
Good luck.
