| Re: What are my options for running a squeezebox system.
I think, confused88, that's the direction i'm heading.
Another thread with some interesting information I've found:
Re: Squeezebox Touch
Originally Posted by Kabeer
Hi there,
Are you able to test whether a 2.5" portable usb drive works with this unit?
Im a little worried if the squeezebox can power the drive.
I haven't tried any self-powered drives (since I don't have any), but I'd be very surprised if there were problems. The designers mentioned at one point that the Touch is designed to be able to supply a bit more than the spec requires if necessary, just in case someone connects a drive which tries to draw too much.
Originally Posted by raffy
Does anyone here know if the ST will play FLAC files directly off a USB harddrive w/o a computer too? I know it works with a USB HD directly plugged into it but not sure if that only applies to mp3 files.
FLAC works fine.
In the "old days" (SLIMP3 and the oldest Squeezebox), the players could only handle a few formats themselves - SLIMP3 only did MP3, and the first Squeezebox handled WAV and MP3. Nowadays, though, all the players can decode more or less anything onboard. I believe the list for the Touch is MP3, FLAC, OGG Vorbis, WMA, AAC, and WAV/AIFF.
TinySC doesn't support transcoding, so a format not on that list won't work unless you're running a separate server, but enough is supported directly that it probably won't be an issue.
Originally Posted by blessingx
Hey j4cbo, could you tell us briefly what is lost by running TinySC only instead of the full-blown SC? I've seen no plugins and web ui, but don't know the extent of sacrifices for its small code-base.
Also is the library scanning process similar to SC for a connected HD and TinySC? Rescan entire library or search for new files (which often created dupes in SC in my experience)?
TinySC isn't a rewrite or a separate codebase; it's just the full SqueezeCenter with a bunch of things disabled / removed to keep the memory footprint down. So the only things that are 'lost' are what's been explicitly mentioned. If you feel like hacking around with the device, you can turn some of those features back on (plugins are pretty easy to re-enable; they just won't be supported officially). Months ago I had an early build which hadn't had the Web interface removed yet, and it was the most glacial interface I had ever seen, so don't hold your breath for that one. :P
For scanning nuances, music services, SB2-and-later device support, synchronization, etc., etc., etc., TinySC should be equivalent to the real thing.
The rescan process is, sadly, pretty much the same at the moment. They're worrying on improving new file detection in order to better deal with removable hard drives, so who knows where it'll be by release.
