AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > Streamers and Network Media Players
LinkBack Thread Tools Display Modes
Old 09-12-2007, 3:32 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Building media centre PC
Looking to build a (virtually) silent media centre pc..
It must be able to cope with HDMI, and be capable of receiving FTA HD via a DVB-S type card
I have no idea on what I need, in the way of decent priced kit that has enough kick to do the job properly. In particular I need a bit of help choosing a reasonably priced, but decent performance:
Video card (with HDMI)
CPU (dual core)
Case (quiet and decent looking for setting below the telly)
I guess while i'm at it, I should allow for future expansion, mainly in the form of dual dvb-t tuner, blu-ray/hd-dvd and large(r) hdd
Any tips welcomed
Pete
mobitune is offline
Old 09-12-2007, 3:57 PM   #2 (permalink)
chris57's Avatar
Thanks: Gave 4, Got 137
Re: Building media centre PC
I'll kick you-off.
What about ditching the video card if silence is the aim. You can get motherboards with HDMI out. Saves the fan noise/heat generated by a video card:-
Intel
http://www.ebuyer.com/product/135080
AMD
http://www.ebuyer.com/search/?strSea...SubcatUID=1953
Sony KDL26S2030U, Popcornhour A100/A110 Network Media Tanks, Sumvision Aquaplus Enclosure, Phillips DVP-5960, Peekton 6006, Yamada 6700, PS3, Harmony 688
chris57 is offline
Old 09-12-2007, 4:25 PM   #3 (permalink)
Thanks: Gave 0, Got 7
Have a look at this thread from elsewhere: http://www.avsforum.com/avs-vb/showthread.php?t=945923
happyuser is offline
Old 09-12-2007, 4:27 PM   #4 (permalink)
rhubarbe's Avatar
Thanks: Gave 88, Got 233
Oh dear, you brave soul. I am just breaking up HTPC MKVI. This one was an AM2 with HDMI out in a Hiper Media HMC-2K53A-H2 case that we modded to an H3 so that we could use the later Abit board with the HDMI.
The PSU had three fans in it, nasty 40mm screamers. The case also has a fan under the HDD but you can't hear that, and the HiperCooler isn't too noisy.
Mine has a DigtialNow QuattroS 2 x DVB-T and 2 x DVB-S PCI-e card.
Two problems with it:
MCE won't play .iso or my camcorder files natively so you have to open an app manually, this means a wireless keypbaord rather than the excellent MCE remote.
It gets too hot.
I have decided to use the mobo and the CPU along with the RAM and the HDD in a new build PC at work, and keep the case and DVD, tuners, etc, and wait until XBMC has been ported to Linux. Then I will buy a Mini-ITX GM965 mobo with DVI and HDMI, a T7700 C2D MODT chip and use a 120W PicoPSU 12-25V PSU with an external laptop brick, and just a 2.5" notebook HDD. This will prevent heat build up in the case and give the nearest thing to a silent HTPC that I can conceive of.
That will be HTPC MKVII, and if that doesn't cut it it really will be hammer time.
rhubarbe is offline
building, centre, media
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Advice on Building HD Media Centre PC pillbury Computer Systems 1 06-07-2007 6:39 AM
Building a Media Centre PC fattony Computer Systems 5 21-05-2007 9:26 PM
Building a new Media Centre/Vista PC - connect to TV x2srj Computer Systems 4 27-02-2007 4:42 PM
Building a media centre PC samcim Windows Media Center Edition MCE 22 25-07-2006 12:23 PM
Building my first media centre PC any advice or recommmendations rusty73 Windows Media Center Edition MCE 0 16-05-2006 6:18 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
