AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > Streamers and Network Media Players
LinkBack Thread Tools Display Modes
Old 26-11-2007, 9:51 PM   #1 (permalink)
Thanks: Gave 1, Got 13
media player + Dual DVB-T + DVD
Is there a device that combines a network media player + dual DVB-T tuners + DVD player? or do I have to build an HTPC?
The TViX 5100SH + DVB-T addon (T530) comes close but no DVD player and as far as I can tell the T530 is a single tuner PVR. Also can the TViX be used as server to stream content stored on its HDD to other network players?
tony_yates is offline
Old 26-11-2007, 9:58 PM   #2 (permalink)
rhubarbe's Avatar
Thanks: Gave 88, Got 233
Re: media player + Dual DVB-T + DVD
No, there isn't. You could buy my HTPC, currently for sale:
For Sale : HTPC in slimline Hiper HMC-2K53a-H£ case
rhubarbe is offline
Old 26-11-2007, 10:13 PM   #3 (permalink)
Bloomin' 'eck that was quick, oh you want to sell me summit
Can I ask how good an HTPC is in operation regards reliability and general use?
I've been playing with MediaPortal on my 'normal' PC and like it, but I haven't used it in anger. What I like about dedicated PVRs, DVDs etc is that you put in a DVD or set a program to record and they seem to work, this is great for the family. What I don't like is the stack of kit I've got; what I'd like is two boxes; AV receiver and 'media player\recorder\server'.
Old 26-11-2007, 10:18 PM   #4 (permalink)
rhubarbe's Avatar
The HTPC is great in that it replaces about three boxes: dvdp, PVR, and NMP. However, it depends on how savvy your wife is. Mine just can't be bothered learning how to mount drives in order to play isos instead of DVDs, and she knows how to use a SkyHD box and can't be bothered to learn how to use a motor for a satellite receiver.
If I lived on my own it'd be a no brainer, but I seem to have this Luddite wife who's into ensuite bathrooms with underfloor heating and isn't interested on bit in anything other than our camcorder footage, which she can get from a networked media player.
Not that I'd prefer to live on my own in any shape or form, of course.
rhubarbe is offline
Old 02-12-2007, 5:17 PM   #5 (permalink)
lookatbowen's Avatar
Thanks: Gave 1, Got 6
Yes there is... it's called a Beyonwiz Dp-S1
But they are rediculously priced if you go by that website.
Toshiba 32WLT58 | PCH-A100 | XBOX 360 Elite | PlayStation 3 | Zektor HDMI5 Switch | Panasonic SA-PT850 | Humax PVR-9200T | Logitech Harmony One | HP Pavilion DV9000 | Nokia N95 | iMac 20" |Wired Gigabit & Wireless Network | Lookatbowen | Stuffonmydesk | Catonmydesk
lookatbowen is offline
Old 07-12-2007, 10:00 PM   #6 (permalink)
Yep, that one seems to do it all. I take it the price is in aussie dollars which converts to roughly £700, at which point I might as well build my own
Old 08-12-2007, 12:44 AM   #7 (permalink)
Thanks: Gave 35, Got 0
Anyone know if others have similar things to this on the way in the next few months?
Neville Street is offline
Old 08-12-2007, 6:28 PM   #8 (permalink)
Thanks: Gave 3, Got 2
PS3 in early 2008 will have a freeview adapter
gavvet is offline
Old 08-12-2007, 7:55 PM   #9 (permalink)
Autopilot's Avatar
Thanks: Gave 164, Got 287
Got any more info on that? link?
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
Autopilot is offline
Old 09-12-2007, 2:35 PM   #10 (permalink)
http://www.pocket-lint.co.uk/news/ne...3-add-on.phtml
http://kotaku.com/gaming/clips/play-...ned-292541.php
gavvet is offline
Autopilot (09-12-2007)
Old 11-12-2007, 12:48 PM   #11 (permalink)
Yeah, there do seem to be one or two devices that almost do what I'm looking for, so it's not beyond the realms of imagination something will appear. Unless there's an unwritten rule when all functions are combined it then gets tagged an HTPC with the price hike to go with it.
For me it seems an HTPC is the way to go, I just want to convince my self of their reliability.
Old 11-12-2007, 2:51 PM   #12 (permalink)
rhubarbe's Avatar
It's not the reliability that's in question. It is the lack of a unified GUI that will handle all of the file types that you will want to play natively, seemlessly and withougt having to use hacks like mounting virtual DVD-Drive under Daemon Tools in order to play ISO.
I built several, and the last one looked to be a go-er, unitl I fopund out how useless MCE really is with file types that Bill doesn't want you to play.
GBPVR was better but not a patch on XBMC.
The only light on the horizon is that XBMC has started to be ported to Linux.
I must not build another HTPC until it can run XBMC.
rhubarbe is offline
Old 11-12-2007, 10:53 PM   #13 (permalink)
although you know you want too
Yep, that XBMC port does look interesting. You'll know better than me but is there any media centre software for Linux? I read about MythTV but I think that's gone commercial or am I wrong?
I think I'm a bit behind you in what I want from an HTPC. Basically, I'm looking at consolidating the devices we have to 2 boxes; a media centre plus surround sound receiver. All it needs to do is be a PVR with dual tuners; play CDs and downloaded music, probably mp3s; play DVDs either from a digital library i.e. ripped DVDs but these I'll rip simply as vobs, or from the normal DVD disc. Seeing as thi swill need to be an HTPC, this will also function as a server for music players in other rooms e.g. squeezebox or summat.
I've been playing with MediaPortal which I really quite like, but this has been on my normal desktop PC so as yet I haven't tried it with a remote to see how it fairs.
Old 11-12-2007, 11:33 PM   #14 (permalink)
rhubarbe's Avatar
I don't know anything much about other Linux software. I did try a couple of years ago to do Linux but I felt like a child in a world I didn't understand.
If I ever do build another PC it won't be in an attempt to get down to two boxes. That IMHO is completely unrealistic. The software that you have to use to make an HTPC happen just isn't good enough. The PVR bits are no good - so I use a SkyHD box; the DVD function is no way as good as a DVD player, and the playing of media files is just nowhere near as good as dedicated devices.
I would only be using XMBC for Linux as a streamer, I wouldn't bother for TV or DVD.
If you don't believe me (and I am sure most people wouldn't) just try it and see how much money you waste. I have spent thousands.
rhubarbe is offline
dual, dvbt, dvd, media, player
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Pioneer DVR-630+Dual layer DVD-R media Subwoofer70 DVD Recorders, Recording and Media 1 04-11-2005 5:33 PM
are there any dvd-r dual layer media yet? Halloween Jack DVD Recorders, Recording and Media 1 29-11-2004 7:01 PM
Dual Layer media and Panasonic HS2 overkill DVD Recorders, Recording and Media 8 24-09-2004 2:23 PM
DVD+R Dual Layer Media Rasczak DVD Recorders, Recording and Media 0 26-06-2004 12:41 PM
Where to get dual layer DVD media? (GTV)Chris DVD Recorders, Recording and Media 3 29-05-2004 5:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
