AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > Streamers and Network Media Players
LinkBack Thread Tools Display Modes
Old 08-11-2007, 1:45 PM   #1 (permalink)
Thanks: Gave 18, Got 1
Wireless Media Centre Player & Hdd Recorder In One?
Anyone know if there is such a thing on the market? I have found a decent hdd recorder on ebuyer here:
http://www.ebuyer.com/UK/product/129392
Problem is it doesnt have wireless connectivity or ethernet connectivity. I have a wireless router sitting under my TV which I would like to connect it into and transfer recorded TV onto my PC to backup for future viewing.
I am also looking to purchase a Wireless Media Centre Player such as the one below:
http://www.ebuyer.com/UK/product/127282
This one is wireless, and also comes with ethernet to connect directly into my router. I can then transfer files back and forth wirelessly, and use it also as a storage device. Problem is - this one dont record TV.
Are there any devices out there that combine these features at a reasonable price? Basically a Wireless Media Centre Player with TV recording functionality.
The key functionality I am looking for - and would even be prepared to fork out for a media centre PC if it has this functionality is;
- Record and Pause Live TV from a Satelite Receiver
- Wireless Connectviity
- HD Out (DVI?) - I have a Sony KDL46W2000 to connect into.
- Large Hard drive (500gb+)
- Optical Out to hook into Surround Sound
- Be able to play video, photo, music from hdd.
I have looked and looked but cant find anything.!?
Any help much appreciated
Pricy147 is offline
Old 08-11-2007, 1:58 PM   #2 (permalink)
Re: Wireless Media Centre Player & Hdd Recorder In One?
This one appears to do the trick - but it has a really small hdd - and not sure if it can be upgraded?
http://www.pcworld.co.uk/martprd/edi...freevents-pctv
£470 in PC world for base unit only!?
Also not sure if I can link my satelite box into this to record satelite TV. I'm sure my feed currently goes into my VCR, then onto Satelite box. This PC only has one Coax feed - so not sure if feed to Satelite to PC will work!?
Pricy147 is offline
Old 08-11-2007, 4:48 PM   #3 (permalink)
or...what about this one????
http://www.pixmania.co.uk/uk/uk/5515...&CodePromo=oui
Seems to do what I want with a large hdd - and much cheaper!
Seem to be quite a few models of this out - anyone know the main differences?
Pricy147 is offline
Old 09-11-2007, 12:15 AM   #4 (permalink)
Anybodeeeeeee??????????
Really interested in this TIVX M-4100SH model. Cant work out if you need to but something extra to record live tv? has anyone got this unit - would really appreciate thoughts. Read on Amazon from a customer review that someone found it incompatible with some file formats.
Anyone know if it can do what im looking for????
Thanks.
Pricy147 is offline
Old 09-11-2007, 8:31 AM   #5 (permalink)
Thanks: Gave 13, Got 13
There's already a thread on the TIVX 4000/4100 models.
TVIX M-4100SH Media HDD
Most say its good and will handle most formats. Yes it can be used as a PVR but you need to buy the seperate module, weather its any good is another matter.
Your probably better off building a HTPC.
willo is offline
Old 09-11-2007, 9:55 AM   #6 (permalink)
Thanks: Gave 26, Got 12
IINM the digital tuner (extra) can record from Freeview but not from Satellite receiver. http://www.mpcclub.com has a good review of the model you're interested.
jenjewak is offline
Old 09-11-2007, 1:58 PM   #7 (permalink)
do you know if there any media centre's that can record from a satelite (NTL) receiver?
By the way (sorry for the ignorance) - what's a HTPC?
Pricy147 is offline
Old 09-11-2007, 4:32 PM   #8 (permalink)
HTPC is Home Theater PC, its a PC but used for more for media. There are loads of threads on this, because its a PC it will play all files etc. I think you can use it to record NTL.
If your looking for a stand alone box to do evrything you want including recording NTL, then I don't think it exists.
willo is offline
Old 10-11-2007, 12:46 AM   #9 (permalink)
Thanks for the tips....these HTPCs sound good - any threads in particular would get be started? Done some searches - but not sure where to start!
Pricy147 is offline
Old 10-11-2007, 9:08 PM   #10 (permalink)
anyone know anything about this media centre pc? 'Seems' to have the functionality im after:
http://www.ambros.co.uk/builds/1117/...er-system.html
Suggests it records digital TV, and can be upgraded with a 500gb hdd! Anyone got one - does it also provide the functionality of a media centre for storing / playing video, pics and music tranferred over from the PC?
Pricy147 is offline
centre, hdd, media, player, recorder, wireless
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Recordings from Media Centre to DVD HD Recorder jwre DVD Recorders, Recording and Media 1 31-08-2006 12:49 PM
Wireless-A Router for Media Centre? rEVILospud Xbox 360 4 01-08-2006 12:25 PM
Help! - Media Centre wireless sender required novice77 Networking 1 10-07-2006 5:25 PM
DVD Recorder or Fujitsu MEDIA CENTRE? MoB Windows Media Center Edition MCE 3 08-04-2006 9:47 PM
Wireless media centre starpoint Networking 7 26-12-2005 6:50 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
