AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > Streamers and Network Media Players
LinkBack Thread Tools Display Modes
Old 05-11-2007, 8:57 PM   #1 (permalink)
Stel's Avatar
Thanks: Gave 0, Got 32
Help Me with server please....
Hi all, Stel here, dunno if i have posted this in the right place but here goes,
In my Home cinema I have 500 dvds which i want to put on a media server with a massive hard drive,I want it to output 1080p via hdmi or dvi and have digital audio out connections to my amp,I also want it to store the pictures of the cases of the dvds so when I use its supplied remote control i can just pull up my whole dvd library on my projector screen.
So basically i want it to store mystuff and plug straight into my amp/receiver, theres no need for it to call media from elsewhere in the house,nor does it need a dvd/blueray/hdd optical drive...
any ideas at all? as i dont know much on these things i have no idea of budget but lets say £1000 for argument sake.
Stel is offline
Old 06-11-2007, 9:36 AM   #2 (permalink)
Autopilot's Avatar
Thanks: Gave 164, Got 287
Re: Help Me with server please....
You really don't need to be paying any like £1000, thats one of the great advantages of streamers over HTPC's. There are a few that fit the bill, it will dig through my bookmarks for you when i get chance later...
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
Autopilot is offline
Old 06-11-2007, 12:51 PM   #3 (permalink)
Stel's Avatar
Thanks mate,look forward to seeing your findings.Is the sort of thing in the link below, if it is then i need something with much more harddrive.
http://www.cclonline.com/product-inf...id=0&tid=27446
Stel is offline
Old 18-11-2007, 1:04 AM   #4 (permalink)
Hi Stel,
no need to spend a grand really i would go for the following:
Pentium dual core 2ghz (has speed step and uses less power in idle quite fan and very cool running)
http://www.scan.co.uk/Products/Produ...oductID=632059
Silverstone LC03 black or silver depending on your style
http://www.scan.co.uk/Products/Produ...oductID=156695
Gigbyte GA73 (Onboard HDMI and DVI and SPDIF)
http://www.scan.co.uk/Products/Produ...oductID=700923
Fanless PSU
http://www.scan.co.uk/Products/Produ...oductID=510107
2 GIG of ram http://www.scan.co.uk/Products/Produ...oductID=402849
And 3 x 750 gig hard disks enough for over 500 films at 4.3 gig each - the reason i chose 750 gig and not 1 tb is 750 are £110 and 1TB are £200 each do the maths!
http://www.scan.co.uk/Products/Produ...oductID=706976
Then add your sundries
jon_1 is offline
server
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
