Visit Netgear's EVA8000 forum
http://forum1.netgear.com/forumdisplay.php?f=85
A Sub board from this forum is the EVA8000 beta forum.
Here's details of the latest firmware 2.0.111
Changes
New Sigma Codecs
Fixed issue where MKV AC3 audio has gaps when AC3 passthru is enabled
Fixed issue where MKV video stops playing after 8-12 minutes
Fixed intermittent squealching when playing MP3 audio
Fixed issue where DIVX video unexpectedly losses audio during playback
Miscellaneous UI fixes and enhancements
More DVD playback and navigation fixes
Fixed DVD trick modes
DVD tags shows correctly
DNS entries now show up if unit fails to get IP via DHCP
Fixed issue where unit locks up trying to set up network
Fixed misinterpreting tags in WMV files
Automatic scan for update file in data folder location
No longer reboots when trying to play MJPEG video
Removed audio pop heard on start of video playback
Playing music now stops currently playing video
Known Issues
MKV DTS audio has gaps if played thru passthru
Subtitles do not work in MKV videos
DVR-MS SD/HD videos gets out of sync audio
Music played via UPnP does not show duration (stays at 00:00) in Now Playing
DTS passthru setting does is always passthru
Using trick modes in MPEG1 causes instability
Unable to play Hauppauge MPEG2 standard profile (no problems with playing DVD profile)
Trying to play Hauppauge MPEG2 standard profile causes instability
No audio with some DRM WMV videos
DVDs with multiple angles don't play properly
TS video playback degrades system stability
Unable to play any video after stopping stuttering video
Support for HDMI 480P with HDMV-DVI cables is broken
(To get around this issue during setup, press the "TV Mode" button
until the mode is changed to one of the supported modes of 720, 1080i, or 1080p)
