Originally Posted by scatterbrain I've come across the Pivos Xios before (and like their remote control BTW!) but cannot find any mention of having XBMC installed if you look on the Apps page of Pivos Technology - Product - XIOS DS Media Play Smart TV Companion there is no mention...or is this some Pivos flavour of XBMC running the whole box?
I've also been in contact with the support at Xtreamer to inquire about their XBMC based Ultra 2. They suggested that it CANNOT play BluRay as it is based on Linux and Linux still hasn't sorted out (reverse engineered) the DRM. Frankly that blows me away that no Linux based XBMC box can play BluRay rips...or was the support at Xtreamer just telling porkies to make excuses for their own weaknesses?
Next010 - does your Pivos XIOS play BluRay rips? |
The Pivos XBMC firmware is a separate thing from the Android firmware.
The
linux/xbmc firmware (<- latest beta) can be installed on the box and it then boots straight into XBMC and fully unlocks the VPU (video decoder on chipset).
The Android firmware which it runs out of the box can run XBMC as
an Android app but it's much more limited at this time.
The VPU on the Pivos XIOS according to them under linux can handle up to about 40Mbps video (similar to Crystal HD VPU) so it could handle some raw Blu-ray video streams provided you've ripped them using MakeMKV and are under the bitrate ceiling though when pressed about this they have said wait and see. There might be more gas in the tank so to speak but it will take time.
The ones I've tried all seem to play without issue but most of my collection is now been compressed into x264 so I haven't done much testing other that a few movies.
What wont work on the XIOS is BDMV playback, you will need to rip with MakeMKV at a minimum with AC3 or DTS audio, no HD audio at this time.
Those Xtreamer guys are pretty shady I wouldn't trust them or go down the Ultra 2 path (which is just a regular PC).
There are other XBMC products coming down the pipeline including the newer 8726-M3 chip which is what Pivos will be using on the XIOS when it launches in Europe (the current model uses the M1).
Also Sigma Designs have their XBMC chip as well in the works hopefully it will finally see the light of day.
